Results 1 to 6 of 6
- Apr 2008
- 6
June 22nd, 2009 06:28 AM #1Can any one recommend a good mechanic who knows Ford Lynxs here in Angeles Pampanga?
Appreciate any help you guys can give...
- Apr 2008
- 6
June 22nd, 2009 06:52 AM #2Or any mechanic you guys know that knows how to do a Ford Lynx...
Getting a little desperate..car's been dead for 4 days now...
June 22nd, 2009 04:11 PM #3
What's wrong? What are the symptoms?
Don't know any, personally... but if you register at http://forum.fordclubph.com , there are some members from your area who may be able to help you.
- Jun 2008
- 51
- Apr 2008
- 6
June 24th, 2009 10:43 AM #5Hey Sir Niky,
Posted this in the FCP forum as well...basically the car won't start...it cranks and all...it starts if i choke the intake (took the filter out..short ram type) as soon as I let my hand off the intake...it dies...
I tried checking the connections of the sensors...cleaned the intake..and the MAF with contact cleaner...still same...only starts when the intake is choked...
Tried checking the fuel pump...i did see one of the contacts a little burnt...but I can't really rule out that it's the main source of the problem...but it does make sense to me...(choking the intake creates a vaccum that sucks the fuel...hence only starts when choked..but i can be completely wrong as this was just an opinion-based hypotesis)...
Car was left out in the rain...out-in-the-open office parking and roofless garage...then suddenly it would start...
June 24th, 2009 12:34 PM #6
Probably electrical then, and yes, probably fuel pump.
One other thing to look for is vacuum leaks... if it starts when you choke it at the intake, there might not be enough vacuum at idle to keep the car running... check all the hoses leading to the intake and the engine coming off the vacuum canister (that black plastic cylinder behind the engine on the passenger side).
Beyond that, difficult to tell... most electrical problems get worse when the car is warm, not on first start.
Eto nalang gawin, kunin starter relay at fuse pump habang ginagawa pa yung key fobs. ...
