Results 1 to 10 of 212
- Apr 2009
- 401
October 25th, 2016 04:18 PM #1For those who are interested in FORScan and how other Ford model owners were able to make changes to some features of their units, please see link below. Hoping we can have similar sharing of information on how we can utilize FORScan to fully utilize features of our Everest.
HOW TO: FORScan - Modify Module As-Built Data (Detailed)
- Apr 2009
- 401
October 25th, 2016 04:32 PM #2I have limited time to tinker so far with the software but I was able to modify the timeout of the power supply on my 12V cigarette lighter, a common complain of owners who use the outlet as power source for gadgets.
FORScan - software to enable/disable features in your truck - Page 22 - Ford F150 Forum - Community of Ford Truck Fans
The default HEX value of most units is 1194 in the first block of the address in the link above. This is the same with the Everest, meaning the timeout is around 1 hour and 15mins. I changed mine to 0005 for a 5-second delay before power is lost. Note that the countdown starts once you open the driver's door after turning off the engine.
Please refer to the table given in the link above to set your own desired timeout. It should be simple enough to understand.
- Apr 2009
- 401
October 25th, 2016 04:45 PM #3I was also able to make this modification to my DRL, but I reverted to original settings as I want the default setting of my DRL.
This is also helpful for those who want to disable their DRLs.
FORScan forum • View topic - Enabling DRL switch on & off option - Ford Everest
- Mar 2014
- 149
October 25th, 2016 07:19 PM #4Nice find bro *ferrarifan. I think *janemar is also working on the remote start. Kailangan kaya ng remote start module?
- Apr 2009
- 401
October 25th, 2016 08:59 PM #5
- Apr 2009
- 401
October 25th, 2016 09:13 PM #6The thing is for Titanium Premium owners, there is very limited modifications that can be made since almost all the bells and whistles are already included, except probably for some hidden functions/displays like oil life, engine temp, etc that takes trial and error to be discovered. Having said that, owners of non-premium models can unleash these features and make their units premium-like.
It will also be much appreciated for people who already made the effort of getting results from their own experimentation to share here the HEX modifications they made thru FORScan, just like in other forums abroad, to prevent redundant work. One can simply post the numbers here and it can be easily implemented thru FORScan by other members.
- Apr 2009
- 401
October 30th, 2016 03:43 PM #7Additional hacks were done with my 2.2 Titanium Premium.
IPC (Trailer Sway) - 720-03-02 - from CC0E 00 to CC4E 00
IPC (Adblue Status) - 720-05-01 - from C068 0202 to E078 0306
IPC (Navigation) - 720-06-01 - from 0000 064A to 0000 0652
IPC (Offroad Gauge) - 720-07-02 - from 0104 00 to 0364 00
The Adblue is indicator only since Adblue is not included in PH models of the Everest. Trailer sway does not kick in unless you have something in tow. Navigation shows compass only, but can be viewed in the dash aside from the Sync2 screen. Offroad gauge works perfectly.
- Apr 2009
- 401
- Apr 2009
- 401
- Feb 2003
- 1,038
October 31st, 2016 12:57 AM #10Nice works Ferrarifan keeps sharing your learnings Hope I could change mine as well..pagnagkalakas loob na hehehe not a techie tsk.
That was the high mileage cars thread:...
The Toyota Fortuner has landed (fortuner pics at...
