^^^ think will not work on everest, you can show the perpendicular parking on cluster but for no used
Sent from my ASUS_T00J using Tapatalk
Is it possible to view digital rpm via forscan instead of the rpm display right now?
Nope for both items.
Please see below for reference. Not all are applicable to our Everest though.
FORScan 2 15-2 17 F15 s - Google Sheets
Tried it once but it didn't work.![]()
Enabled reverse camera feature from trend using forscan.
Sent from my LG-H860 using Tapatalk
Yes po sir. You need the 4dtech harness. If you want oem style reverse cam, please search sa ebay or aliexpress ng trajectory camera, it includes all the cables needed pwede nyo po pakabit sa suking auto shop, then pwede po kayo pa enable sa may mga elm327 dito sa forum kung san pinaka malapit sa inyo if you dont plan to buy elm327. Btw saw elm327 selling sa lazada around 700 pesos ata then you can enable it yourself.
During a SYNC3 V3.0 update, I received a SIGN_ERR01 pop-up. I removed the USB and cycled the ignition. After turning the ignition on, the screen did not turn on, audio power can't be turned on and USB did not have power supplied to my mobile (this was checked a little later). Rear view camera display does not work anymore when in reverse. Basically no power to my head unit. Manual switches for the temperature and fan still work. Checked all fuses under the dash to be ok. Removed negative battery cable from the terminal and reconnected after 30 mins but with no change. Ran FORSCAN and did not find anything wrong (no DTCs) except when I tried to do the APIM diagnostic test which could not proceed and threw the error "the vehicle conditions are incorrect." Should I bring it to the dealer already?
Sir ferrarifan, thank you, napalabas ko na sa Eve ko.
Yung iba dito, pano kaya palabasin? Nakita ko lang sayn sa Visa Thailand, offer nila.
Ung mga parking assist, pwede ba paganahin sa titanium models? Perpendicular assist and semi-auto parallel?
Alin dito yung applicable sa trend? Yung off road applicable sa trend?
Currently looking for somebody or shop who knows where to have the backup cam and 4dtech harness installed. Makati or taguig area sana.
Sir it is possible sa Trend model natin yan... Pwede iactivate lahat mga yan.. TiA..
Sent from my F3212 using Tsikot Forums mobile app
