Results 6,731 to 6,740 of 7777
- Aug 2007
- 98
January 9th, 2018 12:23 AM #6731Ask ko lang waterproof ba yun base ng antenna? kahit wala nakakabit na antenna?Tinanggal ko kasi yun antenna sobrang haba masyado kasi mababa yun lower basement namin kaya feeling ko maski sharksfin tatama.
January 9th, 2018 12:23 AM #6732
Kailan siya maugong sir? Pag bago andar from overnight park? Happened to me before pag sobra tagal naka idling after magdamag sa garahe. Rough takbo ng engine, maugong pero nawawala din shortly after. Kaya ginagawa ko ngayon is kung matagal idle before umandar, press ko gas pedal slightly every now and then till umandar na. So far di na umugong ulit sa low gears.
IIRC, may napost na before (not sure saan) na prolonged idling or warm up is not good sa makina.
HTH
- Jul 2016
- 939
January 9th, 2018 12:40 AM #6733
- Jul 2016
- 939
January 9th, 2018 12:48 AM #6734Ung ugong galing sa engagement ng viscotronic clutch fan(aka. Electro-viscous clutch fan, google na lang.) Ung ugong is ung lakas ng buga ng hangin.
Nag fully ON sya if;
1. A/C is switched on and refrigerent High side pressure is above X-PSI(di ko kabisado, around 150psi ata.)
2. Coolant temp at 100 deg. C and above.
January 9th, 2018 12:54 AM #6735
- Aug 2007
- 98
January 9th, 2018 01:00 AM #6736Autolock
Autounlock
Mislock
Remote Unlock
Switch Inhibit
Yan lang yun nasa settings ng lock walang auto relock need kaya ng forscan yun?
Takot ko kasi baka nakaconektado sa radio yun base ng antenna at pagnabasa ng tubig either sa washing/cleaning or ulan Ma ground yun radio
- May 2007
- 520
January 9th, 2018 01:27 AM #6737
January 9th, 2018 09:35 AM #6738
an absolutely biased law favoring the auto companies. the only way it will work for you (consumer) is if you have a high ranking padrino in the dti.
- 3 repeats of the same problem before you can report
- total 5 attempts to repair before you can file for replacement/refund
- 10% depreciation charged per year or fraction thereof to the consumer. that is even if the car is in the dealer for repairs for 1 year the law still charges depreciation to the consumer. so if it takes them 2 years to admit it is a lemon then you lose your 20% down payment.
January 9th, 2018 12:03 PM #6739
- May 2007
- 520
January 9th, 2018 10:09 PM #6740
Hybrid is the way to go. So you don't rely heavily on the batteries.
Hybrids and EV
