Page 352 of 389 FirstFirst ... 252302342348349350351352353354355356362 ... LastLast
Results 7,021 to 7,040 of 7777
    Jul 2016
    #7021
    Quote Originally Posted by MarkYmarK View Post
    Boss saan casa accept DIY replacement of air, cabin and fuel filter? Thanks
    Overpriced air filter sa casa...
    Lahat ng casa bawal sir. SOP ford PH yan, or else papirmahin ka nila waiver na di mo pinapalitan filters mo at di sila liable pag nangyaring damage related to it... Tropa ko lang SA kaya nakakalusot tayo. Hehe..
    Feb 2007
    #7022
    Quote Originally Posted by Janemar View Post
    I see. Good for you boss.
    Planning to get KNN sana for my filters.
    Kasi i changed to knn with my Strada before, ok lang sa casa.hehe
    Thanks boss
    Oct 2003
    #7023
    How much for 1st PMS? Oil change and air filter, correct? Cabin filter din ba papalitan?
    May 2010
    #7024
    Update lang po.... after almost 10 days.. napalitan na po yung inner handle ng everest sa driver side... c/o ford quezon av.. free of charge under warranty po
    Oct 2003
    #7025
    oxner111,
    Good to hear. Nag-investigate pa ba sila? Or under warranty kaagad?
    Eto pala ung checklist for the PMS ng ford everest. Not sure kung na-post na ito dati.
    May 2010
    #7026
    Quote Originally Posted by zechs View Post
    oxner111,
    May mga natanungan akong casa, yung iba ayaw tapos yung iba under evaluation... so dinala ko sa q av... sabi ko lang 2017 model... then pinicturan lang sabi ok na... warranty naman... or nagkataon lang na very considerate yung nag evaluate...
    Jun 2008
    #7027
    iba-iba talaga response ng mga casa. sa q ave mo ba bro kinuha yung unit mo?
    May 2010
    #7028
    Quote Originally Posted by gongrhey View Post
    Ford manila pero sa q av na release kasi parehas ata sila ANC group.. pero ng inevaluate di nman ako tinanong noong evaluator kung saan ko kinuha yung unit...
    Jun 2008
    #7029
    nice good service. malaking bagay ito sa ating mga owners. good for you din at na-solve na problem ng unit mo.
    Aug 2014
    #7030
    Proper way:
    Use DIN 60 upto Din 75
    Calcium Calcium type
    Reset battery SOC monitor using forscan/ids
    Done.
    Others pero not sure kung ano mangyayari:
    Palit kahit ano batt basta 12volts at kasya sa tray. LOL!!
    Done.
    Sir Janemar,
    Ask ko lang po kung pwede start ang unit natin using jump start cable connected to 3sm Motolite battery (host car engine running). I notice a loud cranking sound while starting my unit in the morning, after office ayaw na start, so I suspect my 2 yr old battery is dead, hence using jump start cable, pero hindi kaya start. Is it my battery or starter motor ang may problema. Papadeliver ako today ng OEM Battery from Ford Balintawak, just wondering bakit hindi kaya ng jump start cable just like what we ordinarily do in our cars. Thanks po.
    Mar 2004
    #7031
    Jump start cable is not up to spec ... or the clamps are not tight enough ...
    Oct 2003
    #7032
    Mahal din ng first PMS. Umabot 10K binayaran. No labor fees pa un since free sa first PMS.
    Sana may option na based sa kilometers na lang ung PMS. Lugi sa akin pag 6 months. Haha Aabot ng 6 months ulit wala pang 10K kilometers.
    Oh and mahina na daw ung battery ko. 12.X volts na lang when they checked. Sabi ng service ibalik daw bago mag 1 year para check nila ulit. Kung mahina talaga, papalitan nila under warranty.
    Feb 2007
    #7033
    We're in the same boat bro.
    The car was left unused since April. Finally able to use it again a few days ago. Felt nothing off. The other car didn't start. So far so good with the Eve.
    May 2007
    #7034
    Ano yung speaker sa front door sa taas yung sa window, twitter ba yun? Pano ma test kung working o hindi
    Oct 2015
    #7035
    Quote Originally Posted by eido View Post
    Maybe adjust fade and balance to extreme front left/right then dikit na lang tenga sa speaker to test. HTH
    Mar 2004
    #7036
    Tweeters are on the door beside in the inner part of side mirror ... Twitter is probably in the headunit ...
    #7037
    Assuming you are in stock headunit setup, put the bass and mids to the lowest setting, then increase treble to max settings. The treble settings drive the output of the twitter. Adjust the fade settings to check which side has any sound.
    Dec 2009
    #7038
    Search in youtube a sound test video
    Feed that audio to your cars head unit via bluetooth or auxillary input, then listen to high pitched sound on those tweeters
    Sent from my GT-P3110 using Tsikot Forums mobile app
    May 2007
    #7039
    Yup yung opposite side nga ng mirror yung sinasabi ko. Will do what you guys suggested. Thanks!
    Jul 2016
    #7040
    Hold mo eject button + seek forward button while at AM/FM menu. This will bring out diagnostic menu ng sync. May speaker test function sya. You'll get it once you're there.
    Sync 2: MyFordTouch Diagnostic Mode - YouTube
    Sync 3: 2016 Ford F150 with Sync 3 Navigation program edit and diagnostic - YouTube
Ford Everest 2015
