Page 261 of 389 FirstFirst ... 161211251257258259260261262263264265271311361 ... LastLast
Results 5,201 to 5,220 of 7777
    Jul 2016
    #5201
    Quote Originally Posted by bigeebabee View Post
    titanium po ako 4wd i think all are same
    2 types ang battery ng eve/ranger, isang medium duty which is the 590CCA rating tapos ung heavy duty na 740-750CCA rating.
    Mabasa nyo yan sa sticker ng battery.
    Dec 2010
    #5202
    Good day mga sir! Questions. May daylight running lights ba ang Trend? Lagi ko kasi pansin na may ilaw kahit naka off yun sa headlight, just wanna make sure. Also, regarding the door locks, kahit naka lock na siya, nabubuksan pa din agad agad kahit di pindutin yun unlock button. I read na it's a feature just in case may accident, mabubuksan agad yun pinto but my concern is pano kung may bata or matanda na bigla bigla na lang mag open ng door, baka maging cause pa ng accident. Tried to read the manual pero parang di ko mahanap sagot. Please enlighten me sirs. Thanks!
    #5203
    Quote Originally Posted by Janemar View Post
    thank you!
    i guess sa Trend is medium duty and Titanium is heavy duty.
    If papalitan ng Motolite or Amaron, magkaiba din ang specs na kailangan?
    #5204
    Quote Originally Posted by rednapula View Post
    Yes, may DRL ang Trend.
    Regarding lock, pwede mo i set yung child lock para ma address yung issue mo.
    #5205
    Bros, just to clarify regarding PMS.
    Should I bring my unit to the casa for 1,000 km and 5,000 km periodic maintenance?
    Sorry for the noob question. Wala kasi search function sa thread e.
    Dec 2010
    #5206
    Quote Originally Posted by G-daddy View Post
    Hello sir, as per casa. Ang sabi saakin no need for the 1k & 5k PMS. Stright sa 10k na next pms ko or 6 mos whichever comes 1st. I guess thats goes for all (everest vehicles) not sure about other variants ng ford.
    #5207
    Quote Originally Posted by Daison77 View Post
    Thanks brother Daison77!
    First time to own a diesel vehicle in a long time kasi. Seems unnatural to me not to have any maintenance done after the first 1000 and 5000 km, not that I'm complaining. Hehe.
    Dec 2010
    #5208
    TBH ako din 1st diesel ko ito. Service manager ng ford ang lumapit pa sakin and briefed me na next PMS ko is at 10k na or 6 mos. And they will get int touch with me pag mag due nako sa PMS period. Also advised me that the 1st pms "may" reach approx 10k daw kasi may discount pa yata sa labor ang 1st PMS. Congrats sa new eve, safe driving !
    #5209
    Thanks boss Daison77.
    FYI lang, Ford Phils has a PMS Schedule with estimated prices on their website:
    Ford Philippines | Maintenance Service
    Don't know if it's been posted here before, but reminder na lang sa mga bagito tulad natin.
    Says there the first estimated PMS cost for first 10,000 km (or first 6 months) is 7,100.
    Aug 2005
    #5210
    Good day guys,
    Ask ko lang kung kasya sa Eve natin ang 9.5" width sa mags?
    Planning to set up kasi with 275 55 20
    Tnx
    #5211
    Quote Originally Posted by acespino2000 View Post
    Good day guys,
    Tnx
    why do you need 9.5 inch mags? e pasok naman sa 8.5 ang 275x55r20 na tires. ganda nga ng porma kasi naka-lobo. i havve 275x55r20 tires using the 20x8.5 stock mags.
    fx edition coming?
    Aug 2005
    #5213
    eyeing an aftermarket mags kazoo 9.5" lapad...not sure kung alang issue.
    anybody here changed their stock mags ? tnx
    Feb 2011
    #5214
    Sir Yebo, nag lift ka ba or kasya na talaga sya? no rubbing issues? Salamat
    #5215
    Quote Originally Posted by pobre24 View Post
    no lift. kasya sya may more than 10mm clearance pa kung naka full turn. at subok ko na sa lubak walang sayad sa tapalodo.
    ang issue pag nag 9.5 e yung offset baka mawala yung 10mm clearance pag naka-turn ng full ang front wheels. sabi nila +10 ang stock mags. so kung 9.5" and same +10 offset ang new mags papasok yan ng 12.7mm, sayad na. dapat zero offset or negative yung 9.5 na mags o gamit ng spacer. issue naman sa negative offset or spacer baka yung outside part naman ang sumayad so need mo i-lift or flare mo yung wheel well.
    pag 9.5 at zero offset papasok lang siya ng 2.7mm so may clearance pa. yun e kung true nga na +10 yung stock mags.
    search mo sa internet tire and wheel fitment calculator.
    Feb 2011
    #5216
    Pwede pala yan eh. I thought automatic may lift pag increase tire size. Maganda naman kasi mags ng eve titanium. Tapos maslobo sya dahil 275 yung tire. I'm assuming na iwas gasgas sa mags kasi nakalubog ng konti sa tire. Best option so far. Salamat ulit
    #5217
    ang bilihin mo na tire yung meron built-in "rim guard". example yung nitto terra grappler na nabili ko may rim guard. nakalabas yung tire wall sa rim kasi indented sa rim yung tire bead.
    Feb 2011
    #5218
    May picture ka ng tires mo sir yebo? Baka pwede makita dito. Thanks
    Sep 2006
    #5219
    Hello Sirs, finally decided to pay reservation fee for Everest 2.2 Titanium Premium the other day. Super excited na kahit baka in 3 weeks pa dumating yung unit. Would you know if merong downloadable user's manual for the 2WD Titanium Premium? Thanks in advance!
    Jan 2017
    #5220
    Quote Originally Posted by peejabi View Post
    Heto: http://www.fordservicecontent.com/Fo...ralia_2015.pdf
    Ford Australia ito pero so far wala naman akong napansin na pinag-iba sa paper manual ko.
Ford Everest 2015
