Page 263 of 389 FirstFirst ... 163213253259260261262263264265266267273313363 ... LastLast
Results 5,241 to 5,260 of 7777
    Mar 2016
    #5241
    Quote Originally Posted by speedik View Post
    sony xperia xa unit ko sir, by the way thanks po..
    Welcome Sir, XA ultra din yung sa akin. Sabi sa website yung S7 sa Samsung , yung XZ premium naman sa Sony, which is puro mga top model lang ang pwede sa AA. Kaya via BT na lang ginawa ko. Di ko alam. Baka may ibang paraan pa Sir, para magamit natin fully yung AA Sync 3 natin. Paki update na lang po.
    Sent from my F3212 using Tsikot Forums mobile app
    Mar 2016
    #5242
    Quote Originally Posted by jml24 View Post
    Using AA since makuha ko yung unit in November. So far ok naman. Installed via apk I downloaded somewhere. Limited ka lang to Google maps for navigation. There are rumors that waze will eventually be Integrated. But so far wala pa.
    Sir baka pwede po pakishare yung download link baka pwede po sa Cellphone natin, Xperia XA ultra. TIA.
    Dec 2010
    #5243
    Quote Originally Posted by ArchiDeos View Post
    Yes sir, pa share ng link. I tried downloading it a couple of times, di nag install yun apk file sa phone ko.
    #5244
    thanks. sabi kasi ng sa sa akin +10. so +44 pala. kaya nagaalangan ako magpalit ng mags before kasi puro ng +20 mga nakikita ko.
    You're welcome sir Struggle ko rin yan dati, di ko ma-figure out ang offset so di ko matancha if yung rims na gusto kong ipalit eh magkasya.
    Initially I went with 25mm spacers on the stock rims (so parang nagging +19 offset siya), and labas lang ng onti sa stock wheel well. It would go well with slim fenders.
    Eventually after much research, di ko rin na-resist ang kamot virus and got the Black Rhino Pismo rims. 20x9.5, +6 offset. Medyo labas sa fenders even if may slim fenders ako, pero ok pa rin naman ang look
    Nov 2011
    #5245
    bakit kaya ayaw magconnect sa sony ko.. binasa ko na lahat ng book, kinonek ko na sa usb port, sa bluetooth wala parin.. hindi ko parin sya. kahit man lang sana yung application ko na map..help help naman po..
    Nov 2011
    #5246
    maging sa iphone 6s plus ng wife ko ayaw din.. ang sabi lang "no application found" may certain application ba na dapat idownload sa iphone at smartphone para gumana sa headunit natin? thanks in advance..
    Nov 2016
    #5247
    Quote Originally Posted by rednapula View Post
    I just did a Google search for the Android Auto apk. I think there are 4 flavors. You just need to make sure that you're installing the correct one for your phone's chipset. Sa akin kasi is S7, and I installed the arm 64 version. The way to test it is it should run independently on your phone even without connecting the phone to Sync. I remember updating the sync software to the latest one before I tried AA. Baka kailangan nyo Sir i Update yung sync. Just connect Sync to the Internet and do an update.
    Sent from my SM-G930F using Tapatalk
    Apr 2016
    #5248
    Sir, try nyo ON si SIRI sa iphone Settings and check there the APP Support. Hope this help.
    Jun 2010
    #5249
    Quote Originally Posted by kapitan_dukot View Post
    Karamihan talaga ng BR, labas sa fender dahil sa offset nila, advantage, no need for spacer, so mas safe sya vs may spacer, un lang, dumihin talaga..
    Sent from my ASUS_T00J using Tapatalk
    Dec 2009
    #5250
    BT is good only for audio streaming
    USB is good only for reading stored music files or additional power supply
    For mirroring you need wifi connection. Its the wifi setting that you need to check. The headunit and the smartphone need to be connected in the same wifi
    Sent from my GT-P3110 using Tsikot Forums mobile app
    Jul 2016
    #5251
    Ford Philippines | SYNC SUPPORT
    Apr 2014
    #5252
    Quote Originally Posted by Janemar View Post
    Sir hingi po ako ng code sa enable offroad menu, disable anc, at auto fold side mirror lincoln style. Hindi po gumagana yung ibang codes dito e. FORScan 215-217 F15s - Google Sheets
    Nov 2011
    #5253
    THanks thanks.. try ko nextime... sa iphone 6s okey na.. try ko nalang ulit sa sony..
    Nov 2011
    #5254
    mukha atang wala sa list ang sony ko puro hi end lahat ang nasa list..hehehe
    Nov 2011
    #5255
    ask lang po ulit mga master sir.. sino na nagpakabit sa inyo ng rearview mirror na may dual cam (front and back) or rearview mirror na may reverse cam?? purpose is para sa rearcam..
    if meron? saan binile at pinakabit..? TIA
    Feb 2011
    #5256
    I was just informed by my SA.
    There is no reflex blue color for 2017 3.2 Titanium Plus (sync 3/black interior) model released so far.
    Can anyone confirm this? Hassle naman if true. thanks
    Apr 2017
    #5257
    Hello sirs. I just want a 2nd opinion. I just talked to my SA now. My unit was supposed to be released this week but according to my SA, hinold daw ng Ford Philippines ang distribution to wait for the price increase this May. Is this true? Sobra na kaming frustrated due to delayed release plus ngayon May price increase pa. I would really appreciate to hear your comments and opinions regarding this matter. Tha k you in advance.
    Jun 2010
    #5258
    It should be the price when you reserved the unit will be honored despite (if there is) the price increase, because price is one of the considerations when you chose to get the everest, tingin wala lang silang stock nung particular na gusto mo, baka sabi lang nila yan, wag mo lang iparamdam sa kanila na atat ka, yayariin ka ng dealer/SA mo..
    Apr 2017
    #5259
    Quote Originally Posted by gomez_ea2 View Post
    I tried reasoning with that already sir pero they were saying that it is not the casa daw that controls the prices but the plant itself. I also tried calling 3 different casas to double check this matter. Ford Davao, Makati and Balintawak where I will be getting my unit sana. Unfortunately, all of them are saying different reasons but bottom line is that all of them won't be able to release any units, either trend or titanium+ units.
    #5260
    No it's not. Ganyan talaga yan pag naabutan ng price increase. Happened to my friends too.
    Totoo naman na new prices na yung ibibigay ng planta sa dealership. I would rather lose you as a customer and sell my one unit to someone else willing to pay a higher price.
    Hindi desperado ang Ford magbenta ng Everest, maraming naghahanap niyan. So they don't have to sell it to you at a price that will hurt their margins.
Ford Everest 2015
