Page 249 of 254 FirstFirst ... 149199239245246247248249250251252253 ... LastLast
Results 4,961 to 4,980 of 7777
    Quote Originally Posted by zagw View Post
    sir marky ganyan din nangyari sa Everest Trend ko last March...ganun din ang nakita ko sa Touch Screen Monitor..but I was expecting talaga na anytime baka bumigay na battery ko kasi it's been 2 1/2 years already since I got my unit, so I wasn't surprised when I read the Monitor that the system is trying to save Battery. I just called Motolite Delivery to change battery, in 30 mins dumating na yung battery..Motolite Gold din ang nakalagay sa akin. The delivery guy attached a power bank to the poles first before removing the dead battery para wala ng irereset sa computer pag kinabit na ang new battery. So far no issues with the Motolite Gold, ok sya.
    I think you still need to do a reset. Si Janemar ata nagexplain before kung bakit need ireset yung battery management ng Everest. Pero kung tumagal ng 21 months new battery mo without issues, I guess pwede nang kahit di magreset.
    Quote Originally Posted by marky2115 View Post
    Sabi ni janemar before it has something to do with the charging rate or voltage. The computer box remembers that the battery is old so it will continue to charge the new battery as if the battery is still the old one. But there was no issue naman after i and another eve owner here chaned the batteries.
    Aug 2016
    Just had my 30th month PMS at Makati Ford...the SA told me there's no need to do a reset for the Everest when you change battery (referring to Battery Monitoring System). Sa ibang model lang daw kelangan.
    On another note, anyone else had problems with the rear aircon vents located sa headliner? walang lumalabas na hangin sa itaas na vents at the rear when I turn on the rear aircon switch. Pero meron lumalabas sa vent located near the rear passenger door on the right side. Meron palang vent dun? What is that vent for, eh deretso sa back ng right second row seat ang direction ng hangin? Seems strange to put an aircon vent at that location. Sabi ng SA, the problem might be the Actuator, they will have to confirm it pa.
    those damn plastic actuators of ford. yan ang karamihang complaints especially sa dashboard. I really wish they change suppliers.
    Jan 2011
    My 2016 everest started with jerking, first when you switch to reverse then after 1 week napunta pag nasa drive. Prior bringing to casa, we scan using obd and no error and last friday check ko yong underneath near transmission, may oil leak.
    Brough to ford alabang and we road test and jerking was there and agreed with mechanic. I left my car to them and got feedback that they will pull down the transmission to check where the oil leak is coming. 15k charge sa pagbaba pa lang ng transmission and will visit them to tomorrow for detail discussion. Sad to say my eve already out of warranty last May only.
    Quote Originally Posted by jonybern19 View Post
    saan banda ang oil leak? sa oil pan? sana pina transmission oil change mo na lng ke "everest garage" it will shift poorly pag low trans fluid. change the transmission oil and filter every 2-3yrs. here is the 6r80 of the everest. it is also used on the ford f150.
    Jan 2011
    Check ko bukas sa ford alabang kung saan banda yong oil leak. Siguro doon ko na muna ipa change oil sa ford at baka kaunti na lang langis at kung ibyahe ko ay lalo pang mag ka issue.
    May 2010
    Hi masters i bought my everest titanium plus 2017 last dec 2016.. lately may naririnig akong tunog sa harap sa may dashboard after pinapatay ko ang makina.. ill try to download po yung tunog. Tnx
    Sent from my iPad using Tapatalk[/QUOTE]
    Quote Originally Posted by oxner111 View Post
    [/QUOTE]
    it could be the ac blender. its a known issue for these multi zone climate control systems.. its plastic and it cracks. you can set driver side to 18c and passenger side to 28c check if it achieves these temperatures check visavis.
    May 2010
    it could be the ac blender. its a known issue for these multi zone climate control systems.. its plastic and it cracks. you can set driver side to 18c and passenger side to 28c check if it achieves these temperatures check visavis.[/QUOTE]
    Hi po, cover pa kaya ito ng warranty.. mag expire kasi warranty ko this december po.
    Hi po, cover pa kaya ito ng warranty.. mag expire kasi warranty ko this december po.[/QUOTE]
    covered yan. hindi naman nyan kailangan ng engine oil hehehe. warranty covers everything naman except consumables like brake pads and wipers and tires.
    next thursday finally aayusin na nila din yun aking mouse scratching noise sa likod ng dashboard. Saklaw sya ng warranty dahil wala naman dapat tunog na emanating from anywhere kapag patay yung engine. Nag mumuangmuangan pa yung casa as if hinde common defect ito ng Everest. Balitaan ko kayo. I just followed the advise of fellow owners here na ilaban ko na ng warranty dahil eventually it will worsen.
    May 2010
    Updates lang sa everest ko na may tumutunog sa dashboard pag pinapatay ko engine.... papalitan na daw this saturday.. hindi nman ako nahirapan mag claim ng warranty... salamat po
    Quote Originally Posted by maillot jaune View Post
    I had the same symptoms with my 2017 Trend, but not not consistently heard or felt. On my 40k PMS, I had it part of my complaints list, but was wary that the symptom would not be replicated during inspection.
    Good news is, using the VCM-IDS, they were able to get a DTC. They tried to clear the DTC and reflash the ACIM(?) module, but the error was still there. The fault is acknowledged by the casa.
    Bad news. The part (blender) is not available and they would still notify me when the part would be available to replace my defective unit.
    Hope this helps.
    It happens to my eve just this month lang pinalitan, good thing under warranty pa cause 5K daw for the parts alone.
    Sent from my SM-A720F using Tapatalk
    Lamson electronics or dunamis
    May 2007
    Hello, ayaw na mag start ng everest namin. Tawag lang ba ako sa motolite to have the battery replaced or do i need to bring it to casa to reset something?
    Meron pala ako battery charger, safe ba gamitin sa everest yung charger?
    thanks!
    Quote Originally Posted by eido View Post
    thanks!
    Charge mo muna battery. If ayaw then replace your battery. No need to bring it to the dealership.
    May 2007
    haven't tried charging everest. do i need to remove the battery and charge or pwede ko charge habang connected sa kotse? normally i remove the battery and charge
    Sent using Tsikot Forums mobile app
    No need to remove, naglow batt din sa akin after months hindi nagamit, may dashcam kasi ako nakarikta nalimotan ko unplug fuse.
    Recharge lang ako but nilagay ko sa low hindi fast charging, after 8hrs yun nag start
Ford Everest 2015
