Results 11 to 17 of 17
- Feb 2003
- 1,038
September 20th, 2019 09:44 PM #11Hindi ba available yan kay MazFord? cguro naman very common parts yan baka naman available. Grabe daylight robbery tlaga yan dapat ni rereport mo yan sa official ng Ford Philippines.
By the way did it manifest some sort of pre-warning? did you observe somethin unusual before the sensor finally went kaput? Sabi ng mga electronics expert this type of sensor most of the time nakukuha lang sa contact cleaner and a bit of disassembly.
- Aug 2019
- 18
- Aug 2019
- 18
- Sep 2019
- 10
October 13th, 2019 04:01 PM #14
November 14th, 2022 01:15 AM #15
is it possible for a vehicle's cpu to fail in sniffing out a bad crankshaft position sensor w/c results in an absence of a check engine light activation ?
- Oct 2013
- 2,537
November 14th, 2022 03:04 AM #16
November 14th, 2022 07:23 AM #17
sometimes the scan tool diagnosis is not enough. it gave you the diagnostic trouble code that tells you the trouble area. for a thorough diagnosis, you should use a digital storage oscilloscope and watch for glitches or dirty signals. what you will be looking for are voltage signal consistency, waveform pattern and hashes. if the signal is not crisp, the sensor magnetic tip might be covered in ferrous particles, or, the relluctor wheel might have deformed teeth. be reminded, there are wires connecting the ckp to the pcm.if the condition of the wires is poor, so is the signal.
Generally speaking sa lahat ng liquid tire sealant.... Not advisable. Pwede as an emergency last...
Liquid tire sealant
