Originally Posted by
bayen
try considering filtering efficiency instead of considering the mere size of the the filter.
Heres a simple comparison to put you into perspective.
Vic filters - 87% efficiency at 40 microns
Baldwin or Fleetguard - 98 % efficient at 30 microns
most, OEM, Bosch, KNN, or other over the counter filters - 98% efficiency at 40 microns
so even if you use bigger filters, it doesnt necessarily mean that your oil will be less contaminated. using vic, it will only capture most particles in the 40 micron size but at a lousy 87% efficiency only unlike other filters that have better filtering efficiency. try looking for the thread here re: remote bypass filtration. that will really give you a good idea how vic filters are.
