[ame="http://www.youtube.com/watch?v=aY4YiEBnJ_8"]YouTube- Will e85 conversion kits damage, ruin or harm my engine [NO!][/ame]
This video shows an engine from a Chevy Tahoe being inspected after running over 100,000 miles on E85, and how the internal engine components look like after using E85 for that long period.
There's a lot of myths surrounding bio-ethanol nowadays. No doubt it's corrosive, in it's 100% form, since it alkaline. But just diluting it to 85% was a good compromise on modern vehicles and still be able to maintain proper lubrication on the engine. Ilang taon na ring ginagamit sa ibang bansa ang E85 with much success. Hindi naman nakakapagtaka na merong nagsusupress sa technology, o nagpapasa ng mga false information, kasi naturally created ang bio-ethanol, fermentation lang ng vegetation. Natural hindi basta na lang uupo sa isang tabi ang mga oil companies sa ganyan katinding kompetisyon, lalo na pagini-introduce pa lang at bagong technology pa. Syempre di sila papayag masapawan agad ng bagong dating. Subconsciously na sinasabi sa mga tao na walang kwenta bio-ethanol gas. Samahan pa ng mga kwentong barbero, yari na.
Compared to E85, E10 is very little bio-ethanol concentration to worry about. It's a way to break in the public on what's new to come. Lower concentration muna sa atin sa umpisa dahil mas maraming mga older type vehicles or basic carburated engines sa atin kesa sa mga bago na fuel injection systems na, then gradually itataas na yan slowly, pero matagal na transition yan. I understand the concern since our carburated or other fuel feed system of older design. But until the concentration goes higher than E10, i can say it can be used with confidence, as long as the older cars or other EFI engine not compatible kuno are maintained properly as usual. The only thing that needed to be done to the is for the engine to be tuned properly to the fuel type (correcting the timing and carb mixture or right throttle adjustment for EFI). Otherwise, it will not run right, and you will experience some hesitations, jerks, sputters, etc. Or if it will make you feel better, you can upgrade the fuel system to something more modern, including the fuel pump, the lines, coated tank, modern carburator and fuel rail for EFI. Then have hardened valves installed, and your older engine like carburated should be ready for E85.
i think kaya marami na sa atin na hindi nagsasabi na hindi maganda ang bio-ethanol like like E10 dahil na brain-washed tayo masyado ng mga nagbibigay ng wrong information about ethanol mula sa mga anti-ethanol groups.
