Results 1 to 10 of 14
- Oct 2015
- 20
April 2nd, 2016 09:34 PM #1I have a 2003 Lancer MX . Recently, napansin ko parang may kumakalasing somewhere kapag nag press ng accelerator, usually kapag mabagal pa lang takbo at kaka start ko pa lang mag drive. Pero , after a while nawawala naman . Ano po kaya ang reason nito? The sound is like kapag may turnilyo na maluwag ( not necessarily sa car) .
April 2nd, 2016 09:50 PM #2
Sounds like the engine mount... its located left and right near the strut mounts.
Also watch this...
https://youtu.be/scFbb43fwqkLast edited by StockEngine; April 2nd, 2016 at 10:02 PM.
- Jun 2015
- 204
- Mar 2008
- 54,226
April 2nd, 2016 11:15 PM #4i used to have one such car. nice and smooth to drive, but guzzled gas.
1. as stock says, check the engine mounts. don't worry. mura lang yan.
2. what fuel are you using? i was using the cheapest fuel in the gas station, and i didn't ping. as vibes says, try using higher octane fuel and see if it disappears.. if it clears up, then you probably need a tune-up or a clean up (decarbonizing).
3. my front shocks made some squeeking noises, before they finally froze. i had to replace 'em both. hey! 'twas cheaper than i thought, but not as cheap as what i would have wished. 7K yata... but not sure. nagpagawa rin kasi ng aux fan..
4. try kutingtinging around the engine, sir. baka may maluwag lang na turnilyo o clamp.. yung air scoop na naka-turnilyo sa front crossbar, maluwag ba?
5. i would recommend valve clearance check, in case they were too loose. but valves make more of a sharp chattering sound that softens after a while..., and not kumakalansing...
so how does your car sip fuel, sir?
good luck.Last edited by dr. d; April 2nd, 2016 at 11:20 PM.
April 2nd, 2016 11:19 PM #5
- Mar 2008
- 54,226
April 2nd, 2016 11:27 PM #6
April 3rd, 2016 09:01 AM #7
Your engine will vibrate if the engine mount is the culprit. Engine mounts are not that cheap though.
- Apr 2016
- 130
April 3rd, 2016 09:11 AM #8any idea what is the range of the engine mount? I'm looking for 1 also since I have a mazda 3
- Oct 2015
- 20
April 5th, 2016 08:46 PM #9
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
