Results 1 to 14 of 14
Threaded View
    Quote Originally Posted by BerrySnow View Post
    I have a 2003 Lancer MX . Recently, napansin ko parang may kumakalasing somewhere kapag nag press ng accelerator, usually kapag mabagal pa lang takbo at kaka start ko pa lang mag drive. Pero , after a while nawawala naman . Ano po kaya ang reason nito? The sound is like kapag may turnilyo na maluwag ( not necessarily sa car) .
    i used to have one such car. nice and smooth to drive, but guzzled gas.
    1. as stock says, check the engine mounts. don't worry. mura lang yan.
    2. what fuel are you using? i was using the cheapest fuel in the gas station, and i didn't ping. as vibes says, try using higher octane fuel and see if it disappears.. if it clears up, then you probably need a tune-up or a clean up (decarbonizing).
    3. my front shocks made some squeeking noises, before they finally froze. i had to replace 'em both. hey! 'twas cheaper than i thought, but not as cheap as what i would have wished. 7K yata... but not sure. nagpagawa rin kasi ng aux fan..
    4. try kutingtinging around the engine, sir. baka may maluwag lang na turnilyo o clamp.. yung air scoop na naka-turnilyo sa front crossbar, maluwag ba?
    5. i would recommend valve clearance check, in case they were too loose. but valves make more of a sharp chattering sound that softens after a while..., and not kumakalansing...
    so how does your car sip fuel, sir?
    good luck.
Unusual sound in the car
