Originally Posted by
Dodge guy
Turbo upgrade will give you 25-30% increase in hp even more if you can bump up fuel delivery and specs the turbo right meaning you can spool it at lower RPM at the same will produce sufficient Air across the power band
Turbo will give you wider gain hp and torque so you will have enough power for low end and top end unlike changing diff ratio you increase top speed you will loose acceleration or vice versa the harder you load a turbo charge engine the harder it will pull until it reach it limits
Also increase increases Klm/l
BTW the turbo charger is actually develop for high altitude application on a locomotive the higher the altitude the thiner the air turbo charger overcome that by forcing more air in the intake. I recommend using CAC or water/methanol injection to cool the charge air and maximize the gain from turbo
