ang ratio ng 11/43 ay 3.91:1 (ibig sabihin nito 11 and "teeth" ng pinion gear at 43 naman ang "teeth" ng ring gear sa differential third member . This figure will tell you that the pinion gear has to rotate 3.91 times to complete the entire circular length of the ring gear), ang 10/43 has a ratio of 4.3:1; 9/43 is 4.78:1; and 8/43 is 5.375:1.
Kung ahunan lang po problema mo, ok na po ang regear "cause it is much simpler than installing a turbo. medyo high speed po yung stock Ring & Pinion ratio nyo na 3.91:1 (11/43). Kung available po yung 10/43 na gearing ok na po yun sa application nyo. D ko na po i-aadvice ung 8/43 kasi hindi na rin po sya gaano makatakbo ng mabilis sa open highway at di rin naman po kau siguro mgpapalit ng malalaki na gulong...
Yung 9/43 naman, ok rin sya pag parati puno ang van ninyo and or parati sa akyatan. ang drawback lang po nya is medyo kukulangin nyo yung bilis nya kahit nasa 5th gear (quinta) kayo sa open highway...
