Results 1 to 15 of 15
    Feb 2012
    Mga sir yung h100 (d4bx engine) po namin makupad sa ahunan anu po MA's OK na upgrade sa dalawa? Nagtanong po ako sa blumentrit may avail na turbo sa van ko pang d4bx daw palit lang daw ng manifold malaki po kaya ang ilalakas ng makina mga sir?
    Sa differential po ang stock gear ratio ng van ko ay 11/43 at ang mga avail po ay 10/43
    9/43
    8/43 anu po kaya swak na gear ratio
    Anu po kaya MA's OK o safe sa dalawa?
    Feb 2012
    Kaya ko poGusto palakasin sa arangkada para po safe pag umvertake lalo pag dadaan po kami sa Santa fe or papuntang baguio
    Feb 2012
    Up ko lang po
    Apr 2009
    ang ratio ng 11/43 ay 3.91:1 (ibig sabihin nito 11 and "teeth" ng pinion gear at 43 naman ang "teeth" ng ring gear sa differential third member . This figure will tell you that the pinion gear has to rotate 3.91 times to complete the entire circular length of the ring gear), ang 10/43 has a ratio of 4.3:1; 9/43 is 4.78:1; and 8/43 is 5.375:1.
    Kung ahunan lang po problema mo, ok na po ang regear "cause it is much simpler than installing a turbo. medyo high speed po yung stock Ring & Pinion ratio nyo na 3.91:1 (11/43). Kung available po yung 10/43 na gearing ok na po yun sa application nyo. D ko na po i-aadvice ung 8/43 kasi hindi na rin po sya gaano makatakbo ng mabilis sa open highway at di rin naman po kau siguro mgpapalit ng malalaki na gulong...
    Yung 9/43 naman, ok rin sya pag parati puno ang van ninyo and or parati sa akyatan. ang drawback lang po nya is medyo kukulangin nyo yung bilis nya kahit nasa 5th gear (quinta) kayo sa open highway...
    Jun 2015
    Turbo upgrade will give you 25-30% increase in hp even more if you can bump up fuel delivery and specs the turbo right meaning you can spool it at lower RPM at the same will produce sufficient Air across the power band
    Turbo will give you wider gain hp and torque so you will have enough power for low end and top end unlike changing diff ratio you increase top speed you will loose acceleration or vice versa the harder you load a turbo charge engine the harder it will pull until it reach it limits
    Also increase increases Klm/l
    BTW the turbo charger is actually develop for high altitude application on a locomotive the higher the altitude the thiner the air turbo charger overcome that by forcing more air in the intake. I recommend using CAC or water/methanol injection to cool the charge air and maximize the gain from turbo
    Feb 2012
    Quote Originally Posted by Dodge guy View Post
    Paano po kung 6psi lang boost nung turbo may effect po ba yon?
    Jun 2015
    7-9 psi is good enough for N/A engines without any modification on on fuel system
    6psi yes air filter nga lang may epecto na diba
    Feb 2012
    Quote Originally Posted by LN106G View Post
    Basta po tumakbo ng 120kph OK na he he dipo kaya maingay diff pag 9/43 na?
    Jun 2011
    Pwede din PO bang re-gear ang mb100?
    Feb 2012
    Ask ka sa blumentrit sir kung may avail na diff pang mb100
    Jun 2011
    Walang differential ang mb100 bro. Sotel...
Turbo upgrade or differential
