Results 1 to 9 of 9
- Sep 2013
- 153
March 8th, 2014 11:49 AM #1Hello,
Just wondering, is it recommended for a SOHC engine to have a turbo installed? Is it applicable for all engines, especially in Honda? Asking for your thoughts.
Another question, I have been looking on some images from the net of engines with turbos. I notice that the AC condenser is missing, I guess to give way for the turbo. Is this always the setup,when you put a turbo on a car, the AC needs to be took off?
Thanks!
March 8th, 2014 12:50 PM #2
March 8th, 2014 02:20 PM #3
- Sep 2013
- 153
March 8th, 2014 03:17 PM #4
- Sep 2013
- 153
March 8th, 2014 08:59 PM #6
March 8th, 2014 10:55 PM #7
March 9th, 2014 12:14 AM #8
SOHC, DOHC, OHV... none of that will prevent you from turbocharging an engine.
What matters is the exact engine model you will be turbocharging. There are some engines that are so well-built, you can more than double the power with a turbo. There are others whose internals are so weak that a mere 50 hp extra can cause failure within a year or two of the installation.
(reliability also depends on how good your tuner and installer are, and how conscientious you are with maintenance).
- Oct 2009
- 2,271
March 9th, 2014 03:23 PM #9nasaan kaya napunta ung power steering pump..
parang kinain ng manifold turbo ung space ng steering pump.
hindi ko makita he he..
Are mandatory seatbelts, and minimum brightness standards for exterior lighting also woke elements?
Carbon fiber hood
