Guys I need some advise sa mga may alam sa ganitong engine.
QG16DE is in my nissan exalta. I encounter hard starting problems then a mechanic inspected my spark plugs and found na basa lahat ng oil and yun daw ang cause bakit mahirap i start. Sabi nung mechanic i should replace the valve cover to fix the leak dahil kasama daw sa valve cover yung mga seals.
Is the mechanic right, or is there any other oil seals / spark plug seal that can cause a leak? Mahirap po kasi maghanap ng valve cover and tingin ko sa casa lang ata meron na brand new. Meron na po ba naka encounter ng ganito sa inyo?
