Quote Originally Posted by rion View Post
I see. this is the most common problems transplanting these engine series. hooking the electrics...
though 2ct pump is mechanical. the electrics connected to the pump is also connected to the computer box. they help balance the fuel and power deilvery to the engine.
most mechanic's solution is to advance the fuel governor. but if you can hook the electrics, it would be better...
experienced personaly not able to hook the complete electrics on the pump transplant, the performance was not good and fuel consumption was bad.
is there any way of fixing this what do i need?
i found that the fuel burn was a little heavy but i thought it was because it was tranny
