I used again cable ties to keep the rocker arms from springing out of position.
Valve Clearance adjustment is recommended after the headbolt tightening...not before. 0.15mm on a cold mitsu 4d56. 0.25 when hot.
TIMING
Install the belt "by-the-book"
then check the timing. rotate by the crankshaft nut about 3 revolutions and check if timing marks align.
