Page 9 of 9 FirstFirst ... 56789
Results 161 to 174 of 174
    Feb 2009
    #161
    2014 toyota altis curb weight 2799 lbs
    1/2" steel cable safe load 4200 lbs
    break point load 21400 lbs
    7/8" steel cable safe load 12900 lbs
    break point load 64400 lbs
    compare the 1/2 inch steel cable to the shaft of the rear shock absorber although the shaft is solid and the cable is stranded
    compare the 1/8 inch steel cable to the front strut shaft again, the strut shaft is solid and the cable is stranded
    even if you hang the whole car on the weaker shock absorber from one side by itself, the shaft should be able to support the weight without significant elasticity.
    but the unsprung weight ( the weight of the suspension components that are not supported by the spring when the car is on the ground, i.e., inflated tires on a wheel, brake caliper, brake hose, the brake fluid inside the caliper, the caliper mount, the strut itself and everything on it, it will not amount to 200 pounds per wheel.
    now son, ask for a refund from your physics instructor
    Mar 2004
    #162
    Sakit ata ng Honda? hehe
    I really hope so. How about if I don't brake na sa humps. How about yung humps na pangit/steep in BGC sa may mind museum?
    Just observe ... might settle after a few days ... or could be just the shocks have given up ... it's ironic that whenever we have car serviced at dealer (specially old ones), there seems to be more problems after we get the car back ...
    Mar 2004
    #163
    TL;DR
    There you have it Cathy ... there is nothing wrong with your shocks according to geometry calculations ... must've also imagined whatever was wrong with the shocks in CR-V before ... but who are we to argue with an expert from abroad ...
    #164
    If I had a job I would, if I get a windfall of money, that's the first thing I will do nga. Saka diba dito sa Tsikot may mga hindi gusto ang CVT? Parang disposable car ata or something?
    Toyota, Mitsubishi and Subaru CVTs have proven to be pretty reliable long term, but if you break it parang no one local knows how to fix it short of replacing the entire transmission.
    I wouldn't mind one in a car that I buy new, but at the same time I'd probably sell it off after 5-7 years. Sagad na siguro to keep it 10 years.
    #165
    Jit is 2023. i don't know how long nissan or jatco has been making their cvts but you would think they would have figured to make it reliable already by now? i have no idea how current nissan cvts are holding up.
    #166
    that's so true. I can't forget when my car was oversprayed when I brought it for service. If the owner isn't particular with the paint hindi mapapansin.
    Even my SA for almost 10 years that I am "chummy" with keeps on adding useless stuff every time I PMS Alam naman niya na EVERY TIME I will have it removed, pinapahaba pa process It seems like protocol na nila yun.
    Oh no!!! It means I really have to sell my car on the 10th year I usually keep my cars for 15 yrs (when problems from old age e hindi na maiiwasan)
    #167
    of course not!
    you're just paranoid.
    there are many same-year model cars as yours, with several times your mileage, and still running fine.
    #168
    That really depends on y your ownership experience. For anecdotal personal experience, as long you will be "aware" of changes to shifting behavior of your CVT and have fluids changed, if and when resets/software updates do not address the behavioral "change", then you should be good.
    Owner 2008 Honda City i-Dsi CVT. We sold it early 2022, so owned it for about (almost) 14 years. It had CVTF changed a total of 4 times if memory serves me right, 4th year, 7th year, 10th year and 13th year through the course of its life. It has had CVT Resets done about 3 times outside of the CVTF change at Honda Casa because battery was removed causing odd shifting behavior or "skipping" of (virtual) gear. almost 90k kms in the Odo at the time we sold it, Honda also checked it and CVT was overall fine, we never really used the "manual mode" except for checking of skipping gears, and I can't remember if it was a "clutch pack" or "flywheel" that needed replacement to remove "Shudder" when you are in Drive and at full stop. The car will shake if you keep it in drive with the brakes applied. So you really have to shift to Neutral. Buyer was informed about this as well as the "quirk" of CVT when it comes to lag time before it really "gets going". hehe!
    2014 Nissan Sylphy 1.6CVT is my current daily. Only 40k kms right now, have had CVTF changed at around 28k kms in the odo as I observed odd behavior after using it to go up Mt Samat even after a "cool down". I used both Sport and Low Modes (as needed) when going up and downhill/ramps based on my experience using the Honda City. Nissan Casa recommended I don't need to change yet but I still had it done along with firmware update/reset (if there is no new version). Still have no issue with the car now when it comes to the CVT at least. Also observed the same issue when the battery was unplugged, had to request CVT Reset to make the CVT run "normally".
    So, it is one of the things I would advice. If you are going to change the battery of your CVT vehicle, make sure you are able to keep the computer box "energized" or have casa reset/update your firmware. You may not immediately observe something going wrong, but over time, when you manage to actually notice, something might have started to break already.... maybe. I err on the side of caution when it comes to CVTs, or computer boxes in general.
    Honda has the specific service charge for it, 600php I think. Nissan NE didn't use to have that service item, but later on had it around 2017/2018 I think. No idea about Toyota but I would expect them to have it if you really want to have it done.
    To add, brother owns a 2009 1.6 Altis G 4AT, not CVT. That still runs, but valve cover gasket has failed twice already causing a dead cylinder/spark plug. Still in "Regular use" today as a service vehicle but short distance only. I think around 90k kms. I think that had the ATF Changed once... maybe? But your CVT for 10th gen Altis really most likely need a change because even the longest interval is usually 40k kms for CVTF change. Lifetime is until it ends it life, so from a "technicality" if it isn't changed and the CVT "dies", then the fluid did last the lifetime of the CVT. hehe! Not sure why Toyota didn't still schedule a change for it. That is really bizarre for me.
    Feb 2009
    #169
    Aussie but with a hint of Bahstin Massachusetts accent.
    changing your corolla cvt fluid
    https://www.youtube.com/watch?v=ZG9L2YryUSo
    #170
    Fair comments, there lots of CVTs from around 2005-2007 still on the road having racked up over 100k kms. Camry 2.4Vs, Mitsubishi Grandis, Lancer Cedia and EX with Invecs-III, etc.
    Forester XTs from 2014 are about to turn ten years old and those are a high power, high torque application.
    My thinking here is not that something is definitely going to go wrong, but at 10 years old something might -- and I'd rather not be on the receiving end of that trouble (and repair bill hehe).
    Feb 2009
    #171
    typically, the wearing parts of a cvt are the chain and the pulleys both input and output and clutches. if the magnet at the bottom of the oil pan doesn't have a lot of metallic debris, it should still be serviceable. if they wear out, just replace the worn parts. just wondering if there are reputable shops in manila that rebuilds transmissions. or the other option, if there are remanufactured transmissions available.
    #172
    but is there a statistical odometer reading, at about which time the CVT breaking down becomes a statistically losing proposition ?
    Nov 2019
    #173
    CVT po ba yung car na yan? I thought manual lahat car mo.
    Aug 2018
    #174
    I want to rant about my 2014 Altis. It only has 41k kms, rarely used and yet I am having problems. It's the first batch of Gen 11 kasi, got it on the first month it was released kaya feeling ko dami pang bugs
    I was driving it today when suddenly I felt the car shaking while on stop (drive and pressing on the brake) Idling went down to 800. I thought it was just a glitch but it went on until I got home (more or less 5 kms). It felt like I was driving on rumble strips and the engine had a hard time going up to 2000 rpm at 60/80 kph. The car was really shaking even on neutral. Good thing I made it home
    Nangyari din to sakin 4 years ago. One known carshop quoted me 13K. Ang sagot, spark plugs. Kasama na sa pms sa daduz auto, pay extra na lang sa parts. Left the shop only paying 5k (though yung atf nun at may ginawang pang ilalim sa labas ko na pinagawa kasi wala silang parts and machine).
    Sent from my LYA-L29 using Tsikot Forums mobile app
Sudden Rough Idling/Car Shaking
