Home service for convenience ... and because you will complain here the agony you had to go through to bring vehicle to shop ...
Do a live stream while it is being fixed and the gang here will happily monitor the mechanic ...
Casa will pick up my car. I'm just afraid they will misdiagnose nga or charge me sky high price. My SA that's nice to me recently resigned so I don't know if the new one will be honest.
trust in the technician's skill and integrity is what is lacking in today's automobile service.
when i do take customer's cars, i document, take pictures of the diagnostic tool display, return used parts( if they are not leaking fluids, wash dirty parts and return to the customer in the box the new part came in with). trust is something that cannot be regained.
on the other hand, i document, take pictures to cover my 6. i already took customers to court for refusing to pay for services and sometimes including parts.
point is, be fair and honest. the service might not be the cheapest in the area![]()
cathy,
a request:
can you take audio/video of the engine running and post it here in the forum?
Yes sabi ko sabi ng Kuya ko. hahaha.
I'm like the most paranoid and praning person, yan nga una ko naisip either transmission or engine problem. Tapos naalala ko Chinese friend ko na marunong sa car e yung CVT niya nagkaproblema kaya binenta niya na City nya
Napagsabihhan na nga ko Aunt ko too young to retire and to get a job, kaya ayoko na talaga humingi pera![]()
Unfortunately people with skills and integrity like you are rare na sa PH casaThey even interchange some parts there. It happened to us personal experience at a Toyota casa that was shut down nga kasi too much fraud ata
I took a video but I don't think I can post it here. How kaya? If anyone has YouTube na I can send the video to post?
OMG there really is a smell. Also, before this happened, my engine was so quiet na sometimes when I am in traffic, I would get confused and check it it's really running. Now it's np maingay and the car is shaking when I am inside, feeling ko nakasakay nga ko sa diesel non maintained old vehicle
If there is a smell then its highly likely that its a misfire since what youre smelling is unburnt gasoline
Which goes back it to being a ignition coil/spark plug issue
Less likely would be a sensor issue
swerte ka pa umabot 14yrs. yin sa akin 7years palit na lahat. ang tell tale sign ko hiccups during acceleration at medyo uneven idle
Yup there's smell talaga. I'll definitely insist on the ignition coil then.
9 yrs though 41k lang mileage ko. Wala akong symptoms or tell tale signs at all. My car kinda drives and smells like new (I take pride in it) Kaya na shock ako bigla na lang naging maalog tapos may amoy gas na na ewan [emoji24] Nahihilo pa naman ako sa amoy na ganun
More than a year na din pala since my last change oil kasi I follow the mileage 5k e that takes me more than than a year
cathy,
if you don't know yet what's causing the engine running rough, even without a code reader or a good quality scan tool, you can find out what is causing it and which cylinder is giving problems.
here's what you do.
after removing the top plastic cover above the cylinder head (if not yet removed), run the engine at idle and disconnect the ignition coil connector from each cylinder one by one. if the engine rpm does not change with the ignition coil disconnected, that cylinder is dead. reconnect the coil back on line, continue disconnecting the other cylinder the same exact procedure again noting for a drop in engine rpm. if you find which cylinder is not contributing to the engine output, shut the engine off and switch the ignition coil of the dead cylinder with another.
repeat the procedure. if the dead cylinder transfers to the one with a possibly bad coil, now you'll know it is the ignition coil. if not, it might be some other cause. do not worry about the 14.5 volts running in the ignition coil feed wires, they will not cause you discomfort.
before coil-on-plug ignition, i used to listen to the misfire using the AM (amplitude modulation) band of the car's radio for static which increases the ticking as the engine speed increases. this might still work with newer ignition systems if the high voltage components are not shielded.
when the misfire is resolved, have the diagnostic trouble codes P0300, P0301, P0302,P0303 and P0304 erased or you can leave them as they will extinguish the MIL (malfunction indicator light, not mother in lawwhen there are no detected misfires after about 50 start-run-shut downs of at least 5 miles each.
I had one experience with my gas-fed Innova before. felt an engine vibration, but I can't recall if there was an engine power loss. malapit lang kasi yung casa sa amin.
buong akala ko ay engine support lang ang problema pero nung na check kong maigi ay hindi yon ang issue. once na kasi meron akong experience sa civic na parang ganoon ang problema nya at engine support lang ang culprit.
it turned out that one ignition coil was busted. our SA only suggested replacing the busted part. The age of my Innova at that time was around 10 years old. IIRC, their charges were reasonable.
Shocking. I thought Toyota was supposed to have bulletproof reliability.
Anyway, wala ba check engine light?
there's no check engine light pag sira ignition coil
i've seen 2 altis same problem as Cathy's
madali lang palitan ang ignition coil
yes.
not all engine problems result in lit up MIL. it usually takes two trips for the light to turn on with the same malfunction noticed. a lot of "mechanics" rely on this MIL thinking it's a tell all. it still takes a good technician to do proper diagnosis. guesswork and anecdotal "yung kumpare ko ganito ang nangyari" is a hit or miss approach and usually a miss![]()
No check engine light. Casa picked up my car na. The car jockey asked kung bagong detail yung car kasi ang kinis, I said alaga lang. So people still think it looks new pero old car problems 😭
Pinaandar pa ng car jockey while doing the checklist. Ang baho talaga ng amoy and when he drove off parang pumuputok yung tambucho 😭
I feel like crying seeing it drive off because I know if I had the money to buy a new vehicle, I need to let it go. I really took care of the car (personally doing the detailing) then this happens.
Also more than a year walang PMS, I kinda feel bad na it's my fault, but then again most of my cars naman talaga more than 1 yr ang PMS kasi I follow the 5k. 2 yrs pa nga, never had engine problems.
