Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Sep 2006
    mga sirs,
    i'm planning to replace my spark plugs, kindly advise which brand to use and the estimated prices
    stock corolla '96 GLi po ride ko. thanks.
    Feb 2005
    mga sirs,
    denso iridium P500 each
    SWS (stick with stock...or NGK-5). its cheap, costs around 70-80 pesos, and it does the job.
    just make sure you replace it every 10k kms.
    minsan kasi pag gumamit ka ng mga iridium tipped or platinum tiipped, medyo nagkakaroon ng pagbabago sa takbo ng oto eh. and besides, these special spark plugs work better in tuned engines. kung stock lang engine mo, again SWS ka na lang...
    Quote Originally Posted by 1D4LV View Post
    +1 kay sir 1d4lv. Stick with stock, mura pa guarantisado pa. I have never been a believer of high end sparkplugs anyways. . .
    Nov 2003
    the equivalent denso or ngk plugs will work fine.
    Aug 2004
    +2 kay 1D4LV... stick with stock. If you want a fancy plug, get the iridium or platinum version of the stock plug.
    High performance plugs often have different heights and temperature ranges from your stock plugs. If you know what you're doing, you can optimize your engine by changing to these plugs. If you don't, you risk poor running... but in the end, whatever power you can gain from high-po plugs isn't often worth the price.
    Dec 2007
    Agreed with everyone. Stock plugs ka na lang. NGK BKR5E ata ang para sa makina mo kung di ako nagkakamali. Check your owner's manual.
    In my opinion "upgrading" sparkplugs and high-tension wires is a massive waste of money for daily driven cars.
    denso or ngk ok nayan
    my 2 cents, I used a Bosch 4 tips, 2 sets in 10 years, beat it, hehe
    IMO, NGK or Denso spark plugs ang gamitin mo....
    5202:threadmil:
    Dec 2007
    eh yung bosch na 4 tip? yun kc gamit ko for 2 years wlang dumi
    Sep 2006
    i settled na muna sa NGK standard plugs, mura pa hehe. they were installed yesterday plus timing adjustment. nawala na tope at lumakas na hatak. I did not know na pag luma na ang car, malaki tulong pala ang konting tune-up.
    Aug 2006
    Ako NGK sa ibang kotse ko pero sa Civic ko Bosch 4 tip iba kasi ang takbo pag Bosch pag NGK parang underpowered
    Nov 2003
    the multi tip plugs are a waste of money imo.
    oem is still the best
    Dec 2007
    well.. all i can say is:
    -for Japanese cars: NGK & DENSO
    -for European cars: BOSCH (or get the ORIGINAL ones.. coz German engines are sensitive as hell!)
    -for American cars: Autolite (good for almost all American cars/trucks/suv's, AC Delco (GM's), Motorcraft (Ford's).. but for the $$$, the Autolite's are good enough.
    also, those Bosch Platinum 2's & 4's are pretty good also.. specially for Fuel Economy, although its expensive, they dont wear out as quick as the conventional "copper" style spark plugs. which I think is also worth it.. again for stock engines.
    but for modified engines, though I would recommend using a non-platinum tipped spark plug. specially for Turbocharged engines. also use a 1 step colder spark plugs. (NGK 6097 baby!! good for engines from 350-1000 whp! coz thats what we use on our Supra's)
    and also, about the Iridium type Spark Plugs.. again IMO, they are only good for stock engines (N/A or Turbo.. as long as they are stock and on stock boost). but if your engine is modded.. the standard Copper type Spark Plugs is the way to go! .. and gap your plugs accordingly as well.
    aite, peace.
    Dec 2007
    sakin po bosch super 4 gamit ko nasa P800 na ata ngayon 1 set 2 years ko gamit wlang palya yun nga lang di ako long driving city lang ako at 4x a wk. ko lang gamit kotse ko pro everyday 1 click lang ako lagi
    Aug 2007
    Not all spark plugs are created equal. Some spark plugs can improve performance, while others offer long life. Some can make your lawnmower easier to start, while others resist fouling
    You'd better consult your car manual and use what it recommends (type) but it woud be no different for the brand, i.e., you can use NGK Champion, Bosh, Nippon Denso etc. All made are not much different in quality but you must use the right type (cold or hot plug) according to the manual.
    Jun 2007
    Quote Originally Posted by sboogie View Post
    +1 iba talaga OEM
    Quote Originally Posted by DON2003 View Post
    My original OEM Denso Iridiums lasted me for about 90,000 kilometers.
which spark plug brand
