Results 1 to 10 of 27
- Sep 2006
- 2,746
January 18th, 2008 11:07 AM #1mga sirs,
i'm planning to replace my spark plugs, kindly advise which brand to use and the estimated prices
stock corolla '96 GLi po ride ko. thanks.
January 18th, 2008 12:07 PM #3
SWS (stick with stock...or NGK-5). its cheap, costs around 70-80 pesos, and it does the job.
just make sure you replace it every 10k kms.
minsan kasi pag gumamit ka ng mga iridium tipped or platinum tiipped, medyo nagkakaroon ng pagbabago sa takbo ng oto eh. and besides, these special spark plugs work better in tuned engines. kung stock lang engine mo, again SWS ka na lang...
January 18th, 2008 12:27 PM #4
Tsikot Member Rank 5
- Nov 2003
- 3,849
January 20th, 2008 04:49 PM #6
+2 kay 1D4LV... stick with stock. If you want a fancy plug, get the iridium or platinum version of the stock plug.
High performance plugs often have different heights and temperature ranges from your stock plugs. If you know what you're doing, you can optimize your engine by changing to these plugs. If you don't, you risk poor running... but in the end, whatever power you can gain from high-po plugs isn't often worth the price.
January 21st, 2008 12:11 AM #7
Agreed with everyone. Stock plugs ka na lang. NGK BKR5E ata ang para sa makina mo kung di ako nagkakamali. Check your owner's manual.
In my opinion "upgrading" sparkplugs and high-tension wires is a massive waste of money for daily driven cars.
- Sep 2003
- 107
Traffic!
