Results 11 to 20 of 27
- Sep 2006
- 2,746
January 22nd, 2008 02:46 PM #12i settled na muna sa NGK standard plugs, mura pa hehe. they were installed yesterday plus timing adjustment. nawala na tope at lumakas na hatak. I did not know na pag luma na ang car, malaki tulong pala ang konting tune-up.
January 26th, 2008 07:45 AM #13
Ako NGK sa ibang kotse ko pero sa Civic ko Bosch 4 tip iba kasi ang takbo pag Bosch pag NGK parang underpowered
Tsikot Member Rank 5
- Nov 2003
- 3,849
January 27th, 2008 06:00 PM #16
well.. all i can say is:
-for Japanese cars: NGK & DENSO
-for European cars: BOSCH (or get the ORIGINAL ones.. coz German engines are sensitive as hell!)
-for American cars: Autolite (good for almost all American cars/trucks/suv's, AC Delco (GM's), Motorcraft (Ford's).. but for the $$$, the Autolite's are good enough.
also, those Bosch Platinum 2's & 4's are pretty good also.. specially for Fuel Economy, although its expensive, they dont wear out as quick as the conventional "copper" style spark plugs. which I think is also worth it.. again for stock engines.
but for modified engines, though I would recommend using a non-platinum tipped spark plug. specially for Turbocharged engines. also use a 1 step colder spark plugs. (NGK 6097 baby!! good for engines from 350-1000 whp! coz thats what we use on our Supra's)
and also, about the Iridium type Spark Plugs.. again IMO, they are only good for stock engines (N/A or Turbo.. as long as they are stock and on stock boost). but if your engine is modded.. the standard Copper type Spark Plugs is the way to go! .. and gap your plugs accordingly as well.
aite, peace.
January 27th, 2008 08:21 PM #17
sakin po bosch super 4 gamit ko nasa P800 na ata ngayon 1 set 2 years ko gamit wlang palya yun nga lang di ako long driving city lang ako at 4x a wk. ko lang gamit kotse ko pro everyday 1 click lang ako lagi
January 27th, 2008 11:43 PM #18
Not all spark plugs are created equal. Some spark plugs can improve performance, while others offer long life. Some can make your lawnmower easier to start, while others resist fouling
You'd better consult your car manual and use what it recommends (type) but it woud be no different for the brand, i.e., you can use NGK Champion, Bosh, Nippon Denso etc. All made are not much different in quality but you must use the right type (cold or hot plug) according to the manual.
January 28th, 2008 09:13 AM #20
mikel arteta coat 2023 williamjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
