Sabi nila kung konti lang yung smoke from crankcase ok lang for a diesel. Sa oil filler cap usually tinitingnan. If a steady stream of white smoke is there it might be time for an overhaul.
Unless you've been losing a lot of oil between oil changes I wouldn't worry. If you are, have a compression test done.
*OJ
Does the Innova D4d have a pcv valve? Always thought it was just a breather hose.
No smoke from oil cap. Very little smoke from the dipstick, na pansin.
