Results 1 to 20 of 21
    Jan 2013
    Hello mga Paps and Mams,
    Is it bad to use Cruise during break-in period? Because you will have a constant RPM. Hindi naman maiiwasan sa Hi-way ang constant rpm, maliban nalang sa zigzag roads.
    And I think sa factory palang binirit na yung engine.
    Thanks.
    completely fine.
    When I broke-in my 2019 Camry SE, I stuck to roads with 40 mph to 50 mph stop and go traffic. I kept RPM no higher than 4000. Later in the break-in period, I started using the paddleshifters and experimented with shifting at different RPM ranges, while remembering to keep RPM at 4000 or less.
    Once the odometer went past 630 miles, the break-in period was over. Only then did I take the car to the freeway, accelerating to freeway speeds (65 mph to 85 mph) and taking it beyond 4000 RPM, usually 5000 and less than 6000 RPM for spirited acceleration (red line is 7000 RPM).
    Oh. The manual stated the first 630 miles is the break-in period. It varies, depending on the car.
    Break-in rule of thumb...
    cruise control isn't slow.. 40kph-100kph will be at the mid rpm. It'll be fine
    Just not at extended constant speed. It's just 1k kms worth of wait.[emoji4]
    Jan 2013
    Used it in NLEX at 100kph which is fast
    Kahit naman kasi di gumamit ng cruise, constant talaga speed at rpm sa nlex hehe
    Quote Originally Posted by kris_13 View Post
    100kph is around 2000rpm(plus or minus 250rpm depeding on vehicle) its the sweetspot for most engines. thermal efficieny is near the peak.
    120 is fast as it is away from the peak thermal efficiency...this should be avoided during break-in
    May 2019
    Don’t overthink it. Just drive normally and not like “drive it like you stole it” type.
    Congrats and drive it in good health.
    Feb 2014
    o ayan it's already idiot-proof language
    do not maintain constant speeed for long periods. this means don't use cruise control at particular speed for long periods
    what's so difficult to understand w/ this simple sentence
    Doable... 1k kms lang naman pala... [emoji106] thanks for sharing travi bai... sa instructions na yan parang sinasabi nila na gagamitin mo yung sasakyan na hindi masyadong agressive and not really conservative... hehehe for 1k kms... after that, you can go back to your driving style...
    Apr 2012
    Quote Originally Posted by Vodka View Post
    well be doubtful if it says sacrifice a goat or something. but that babad at constant speed is on every user's manual i've read but i'm not an engine nerd so i can't really say for sure. but i think it has to do w/ resonance. at particular engine RPM AND load certain spots on the parts are polishing against each other. if you vary the RPM or load other spots get polished
    i see. but imo, if it concerns internal parts getting polished, i would say mas maganda siguro kapag constant speed para smooth ang rubbing ng parts.
    yes, bottomline huwag muna isagad patakbo while its new
    Feb 2014
    Dude not your expertise not mine either. But read about resonance and it'll make sense
    Aug 2017
    My old practice... 24hrs at idling... on over 50 cars
    Feb 2014
    Quote Originally Posted by SidCoronel View Post
    congrats on your old wives tale break-in method. i'm sure it's awesome
    i'm sure other people have even "better" methods feel free to chime in
    hahahaha ayus! mapapaisip mga ney sayers lol.
    meron na ba umabot 999,999km sa fleet mo?
    Just drive normally and use all the features of ur car the first day you have it.
    Apr 2012
    do not race the engine...okay
    do not drive constantly at full throttle...okay
    avoid unnecessary hard stops...pwede
    avoid full throttle starts...pwede
    do not maintain one constant speed...ano daw rason? idiot kwestion lang[emoji848][emoji2960]
    Feb 2014
Cruise control during break-in period
