Page 1 of 3 123 LastLast
Results 1 to 20 of 48
    Oct 2015
    Car is toyota innova diesel 2014model.
    80tkm odo
    When the engine reach operating temp(Temp guage needle is above 5 bars) i check the dipstick and saw some puff of white smoke coming out. It was barely visible.
    Mas mataas pala yung consume ng diesel. Since my last change oil.
    From 6.9kpl to 6.4kpl accrding sa front info display.
    Ngayon 1 full tank only reaches 290kms. Dati 320kms
    Should i be worried?
    Quote Originally Posted by dieselpowah View Post
    80tkm odo
    Yes that is a problem imho. Have it checked by the casa or some reputable auto shop.
    Sent from my SM-G965F using Tapatalk
    Jan 2009
    Sounds suspiciously like blow-by.
    First, check the PCV system... PCV valve and all.
    Jan 2008
    Smoke from dipstick is normal for a diesel engine.. also you should not check the oil level or pull out the dipstick while the engine is running!
    Check your fuel filter and air filter or try changing fuel brands and see if your consumption will improve
    Sabi nila kung konti lang yung smoke from crankcase ok lang for a diesel. Sa oil filler cap usually tinitingnan. If a steady stream of white smoke is there it might be time for an overhaul.
    Unless you've been losing a lot of oil between oil changes I wouldn't worry. If you are, have a compression test done.
    *OJ
    Does the Innova D4d have a pcv valve? Always thought it was just a breather hose.
    Jul 2013
    yun din naisip ko...
    for me it's the easiest way to see the condition of the engine... lalo na when looking at a second hand car...
    yung iba nga buong oil cap ang tinatanggal... pero since maliit butas nung dipstick, mas madali makita yung kung may smoke
    80tkm odo
    annual oil change ba? for the past 8years?
    Feb 2014
    if your DIPSTICK is smoking you should be very worried
    Oct 2015
    Change oil every 10tkm more or less.
    Pag regular oil. 5tkm to 6tkm.
    Tried opening it from the oil cap. Was not able to see the smoke. But yung oil ay tumatalsik from the oil cap. And may malakas na blow ng air.
    Oct 2015
    How can i check the pcv valve? And i dont know where it is.
    And one more thing. Napansin ko lang yung tension pulley may slight wobble. Baka kase connected.
    I'd do 5k/6 month oil change interval with regular oil vs 10k/1 year unless I run on the highway most of the time. Iba na kasi ang traffic ngayon.
    Nagbabawas ba ng langis between oil changes?
    Oct 2009
    piston ring ,,
    Oct 2015
    Air filter just change it last week. Akala ko yun lang problem ng increased fuel consumption.
    Mas lumakas lang yung hatak after putting in new engine air filter. But no noticable change sa fuel consumption.
    Jan 2009
    *OJ
    TBH, not sure. Just speculating.
    Aug 2017
    Quote Originally Posted by jaypee10 View Post
    piston ring ,,
    The most likely culprit... I agree.
    Aug 2017
    *OJ
    Agreed, agreed, agreed. However, I would defer the overhaul... When the smoke is unbearable and the oil consumption is like 1L a week.
    I have an Innova Grab car with the same dipstick smoke issue since 2016... Now 3 yrs later, 160k km... Still serves its purpose, no worsening of smoke, eats 1L oil every 6wks...just in time for its change oil
    Aug 2017
    D4D is turbocharged... The engine air filter should be changed (not cleaned) every other oil change, else save money for a turbocharger breakdown... About P60k
    Jul 2013
    Same question... kumakain na ba ng langis and gaano kalakas?
    Oct 2015
    About 1 liter sa tinakbong 3t km to 4tkm.
    Naalala ko 2 or 3 weeks bago ako nag change oil (every 5Tkm) nag add ako ng 1 liter sa engine.
    Oct 2015
    *OJ
    No smoke from oil cap. Very little smoke from the dipstick, na pansin.
Smoke from dipstick.
