Results 61 to 70 of 70
May 22nd, 2009 10:45 PM #61
nabasa ko dito noon.
simota filters delivers more or less the same air by k&n but the filtering capabilities put it down.
May 23rd, 2009 12:48 AM #62
- Oct 2007
- 55
May 23rd, 2009 08:51 AM #63Mga Sirs!
Meron po bang k&n filter para sa honda type z? i was thinkin to buy a simota air filter but having second thoughts. Baka hindi worth... gusto ko kasi sana maimprove kahit pano yung acceleration ng auto ko. Kung meron how much kaya budget? and san akaya may available, meron kaya neto sa evangelist?
Help naman po... thanks!
- May 2009
- 22
May 23rd, 2009 09:58 PM #64Mga Sir,
musta po, meron lang ako simple question..i'm planning on changing my air intake and filter, kotse ko is a 90 toyota gl 16valve, 2e engine with carb, i'd like to use something like a cold air intake or yung mga drum intakes (hindi ko alam tunay na tawag po dun)...
problem is, my old carb has 2 air bleeds sa intake manifold, one coming from the engine cam manifold at yun po isa is part of the carb air regulator (baka po mali mga terms ko pero i hope you understand)
un po kasi simota drum intakes at yung iba like cone+pipe intakes e isa lang po ang bleed port..
question (sa wakas)...ano na gagawin ko sa air bleed mula sa engine? sasarado ko na lang? magbuibuildup po presure sa cam manifold...
goal ko po is to ensure the coldest, densest, strongest air flow para po makapiga pa ng ilang hp...
baka meron po kayo idea...
at san po ako makakakuha ng kit? (willing to spend po, pinagipunan ng todo)
salamat po (first post ko to)
- Apr 2008
- 537
May 24th, 2009 03:33 PM #65minimal lang ang naging effect sa makina ng tito ko nung binilhan namin ng simota halos walang pinagkaiba sa stock but the only good thing is "the look" kasi nga naman ang ganda talaga tignan sa engine bay mo kapag may ganyan ka at di lang yan mmura kasi eh.
ok na ok ang paliwanag ni Auto_xer at isa pa may patunay naman ang K&N na talagang magaganda at mas effective ang mga filters nila dahil ako sinubukan magkaibang brand ng cone filters yun ay ang simota at K&N.
ang ginamit ko na pang test ay yun vacuum cleaner ng tito ko sa bahay nila gumawa ako ng adaptor para umakma ang bawat isang cone filter, una kong tinest ay yun cone filter ng tito ko sa honda nya na simota na medyo bago pa nang itest ko sa pamamagitan ng vacuum cleaner nilagyan ko ng papel ang cone fitler na ginupit ko sa tatlong piraso.......... ok malakas parin ang suction ng vacuum kahit nilagyan ko ng simota cone filter dahil nakikita ko naman yan dahil na rin sa ipinatong kong papel sa cone filter habang gumagana ang vacuum pero ang napansin ko lang ay medyo matagal tanggalin ang papel sa cone kahit umaandar ang vacuum at kung patay naman ang vacuum ay bigla naman na huhulog ang papel mula sa filter cone na simota.
nung hiramin ko naman ang cone filter na K&N na medyo gamit na gamit mula sa kaibigan ko para itest, nung makita ko ang itsura sabi ko ay wala naman pagkakaiba ito sa simota pero para malaman tinest ko rin ng katulad ng pag test ko sa simota, nang itest ko na ang napansin ko sa papel habang tinatanggal ko para ba sya isang pusa na kumakapit pa rin habang tinatanggal mo at yun tinest ko ulit at ibinalik ko ang papel sa cone filter ng K&N habang umaandar ang vacuum pero nung pinatay ko ay nakakapit pa rin ito sa filter ng mga ilang segundo at saka palang nalaglag........... tinest ko ang mga yan na nasa parehas ng lakas ng suction ng vacuum.
ngayon dun ko nalaman na hindi pala presyo ang pinaguusapan pag dating sa bilihan ng air filter kundi kung gaano ba ito kabisa sa mga makina para mag gain ng power so ibig sabihin lang na talagang mas effective ang K&N talaga kahit medyo pricey ito.
May 27th, 2009 07:44 PM #66
Actually, may 2 difference b/w K&N and Simota: cheaper ang Simota at mas matibay ang K&N (lifetime warranty).
Sa design, halos pareho lang. Depende sa choice mo.
From my experience with Simota (i installed it in my Maxima, Sentra, and City), feeling ko e lumakas naman. What I did is a bought a K&N cleaning kit para ma-maintain ang effectiveness ng Simota ko. So far, they are doing just fine.
I think merong gawang Taiwan at Australia na Simota. As compared to stock, mas OK pa rin ang Simota. Test it yourself. Blow air thru the stock and Simota filters. Observe the flow volume by feeling it with the back of your hand. You'll be the judge.
Bottom line is, kung may budget kang malaki, go for K&N.
May 27th, 2009 08:20 PM #67
May 27th, 2009 08:35 PM #68
- Oct 2009
- 77
November 4th, 2009 12:54 AM #69sir magkano yung K&N na short ram intake for a 97 honda civic VTI model po? saan ba nakakabili nun?
November 4th, 2009 02:23 AM #70
Iyong K&N air filter ay mayroon sa HRC Auto Supply #51 Banawe ST QC.
TEL.# 712-03-03. Tawag mo na lang iyong presyo.
Because most off-the shelf electricals and accessories (headlights, infotainment, horns) are still...
Hyundai Philippines
