Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 70
    #41
    bubuhayin ko lang yong thread na to
    Here's a link which shows a comparison between a K&N drop in vs. a Simota Cone type
    http://home.earthlink.net/~mojako/data/Simota_DynoRun.mht
    Aug 2004
    #42
    question lang??
    may nabibili ba dito sa 'Pinas na Cold Air Intake ng Simota??
    K&N and Iceman ksi lagi ko nakikita eh...
    Salamat!!!
    Aug 2004
    #43
    correct me if im wrong. ang alam ko po sir pag cold air intake (cai) mahahaba yung pipe down to the fender at good quality yung pipe yung pipe na ginagamit. so if u have long pipe and insulator sa heat then pwede cguro yung simota na magiging cai? hehehhe
    Aug 2004
    #44
    aba oo nga noh...ba't di ko naisip yun!!!
    kaso nga lang mahal yung mga cold air intake kits sa mga stores dito. probably bili na lang ako ng K&N na filter tapos kabitan ko na lang ng cold air intake pipe. but where am going to buy those pipes (besides PVC pipes), how much, and does K&N or Simota sells cold air intake pipes individually dito sa 'Pinas???
    i heard someone telling me na may Iceman imitation daw. meron ba nun?
    anyone?
    thanks in advance....
    Aug 2004
    #45
    di ko maintindihan kung bakit reset pa ng ecu?? ecu is used sa mga sensors. wala naman sensor sa air filter nasa throttle body naman.
    Aug 2004
    #46
    No problem with using Simota as a CAI, but custom pipes that long cost $$$. Maybe 4-5 thousand at eRL on P.Tuazon (by Chocolate House)
    mojako, interesting yung article, pero K&N panel versus simota cone... syempre panalo Simota... more interesting kung K&N cone versus Simota cone... The margine will be the same in the opposite direction.
    yan_168, most EFI cars have a Mass Air Flow/Pressure sensor right behind the filter.
    And usually, you don't have to reset the ECU... it will work just fine... or if it doesn't, it will adapt in a few hours.
    #47
    eh sir paano naman dun sa carb ang auto meron din bang air filters for carb ang K&n?
    #48
    yup meron din sa pagkakaalam ko :D
    Aug 2004
    #49
    guys, question. if a car's engine is efi and you want to replace the stock filter with an aftermarket type, do you have to reset the ecu? if so, how do i do this?
    thanks in advance!
    ---- hmmm, ngayon ko lang narining to ah. 2 beses na kasi ako nagpalit ng filter. dati simota then after few months k&n na. basta pag kabit start na kaagad. wala naman ako naexperience na sira or ano. mag2years na rin yung k&n sa kotse ko. ok pa rin hangang ngayon. ang mumura ng k&n nyo ah.hehe san nyo nabibili yun? yung akin kasi 4,200 mas mahaba pa siya sa regular type. filter lang yun wala pa tube. yung tube ko is simota.
    Aug 2006
    #50
    gud day!!mag kano ba racing filter ng toyota corolla gli 94 model? pls reply asap tnx
    Aug 2006
    #51
    Quote Originally Posted by ;24778
    Yup! they do. as a matter of fact, i saw these K&N filters in alabang, 2800 lang hehehe!
    gd day!!magkano b racing filter ng toyota corolla gli 94 model?tnx
    Aug 2006
    #52
    sir magkano b racing filter corolla 93 model na gli
    Jan 2003
    #53
    simota? siguro mga 1.5k sa banawe.
    im using HKS supa hybrid filter on my a32. after installing biglang tumaas yung rpm. normal lang daw yun since nag aadjust pa yung ECU. after a few minutes ok na.
    Feb 2006
    #54
    Tanong lang po... saan ba gawa yung Simota?
    Kasi, um, parang tamang-tama e sumisimot ng hangin...
    #55
    sir auto xer yung nilagay nyo na k&n sa expe, drop in po ba? no problems lumabas? sabi kasi nila mag check engine raw pag nilagyan ng ibang filter.
    Oct 2008
    #56
    Quote Originally Posted by Ungas View Post
    Just as I thought, it's not enough to disrupt the fuel/air mixture. :D
    Meron kasi nagsabi sa akin nun this might cause abnormal engine performance. As in baka "DAW" maging palyado or something. Anyway that was his point not mine. Kaya nabanggit ko lang just to clear things off my mind. :D
    it may happen, esp on computerized engines (vvt-i, vtec) lalo na kung mali yung pagkakakabit nung air intake. the fuel air mixture will be so lean that it would cause knocking. (the feeling when you go below ideal idle rpm)
    in general, air intakes (short and cold) will increase hp at higher rpms, especially on cold air intakes. it will increase fuel efficiency due to increased hp. i don't know its effect on the torque though.
    Oct 2008
    #57
    Quote Originally Posted by yan_168 View Post
    hmm cold air intake dito? better think twice bro.
    june to december and ulan satin. unless me bypass valve yung intake mo..
    and kung meron man, swerte ka bro, kasi mayaman ka hehehe
    Dec 2008
    #58
    mga masters, i have read some feedbacks that simota filters are not good. there were test results showing that stock filters actually perform better than simota filters. ano masasabi nyo dito?
    #59
    Quote Originally Posted by arnarn View Post
    pwede, ive seen some simota filters na ang kapal ng filter. halos ga karton ka kapal. (cone filter to ah)
    #60
    nabasa ko dito noon.
    simota filters delivers more or less the same air by k&n but the filtering capabilities put it down.
Simota Intake / Air Filters
