Mga Sir,
musta po, meron lang ako simple question..i'm planning on changing my air intake and filter, kotse ko is a 90 toyota gl 16valve, 2e engine with carb, i'd like to use something like a cold air intake or yung mga drum intakes (hindi ko alam tunay na tawag po dun)...
problem is, my old carb has 2 air bleeds sa intake manifold, one coming from the engine cam manifold at yun po isa is part of the carb air regulator (baka po mali mga terms ko pero i hope you understand)
un po kasi simota drum intakes at yung iba like cone+pipe intakes e isa lang po ang bleed port..
question (sa wakas)...ano na gagawin ko sa air bleed mula sa engine? sasarado ko na lang? magbuibuildup po presure sa cam manifold...
goal ko po is to ensure the coldest, densest, strongest air flow para po makapiga pa ng ilang hp...
baka meron po kayo idea...
at san po ako makakakuha ng kit? (willing to spend po, pinagipunan ng todo)
salamat po (first post ko to)
