Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 70
    #41
    bubuhayin ko lang yong thread na to
    Here's a link which shows a comparison between a K&N drop in vs. a Simota Cone type
    http://home.earthlink.net/~mojako/data/Simota_DynoRun.mht
    Aug 2004
    #42
    question lang??
    may nabibili ba dito sa 'Pinas na Cold Air Intake ng Simota??
    K&N and Iceman ksi lagi ko nakikita eh...
    Salamat!!!
    Aug 2004
    #43
    correct me if im wrong. ang alam ko po sir pag cold air intake (cai) mahahaba yung pipe down to the fender at good quality yung pipe yung pipe na ginagamit. so if u have long pipe and insulator sa heat then pwede cguro yung simota na magiging cai? hehehhe
    Aug 2004
    #44
    aba oo nga noh...ba't di ko naisip yun!!!
    kaso nga lang mahal yung mga cold air intake kits sa mga stores dito. probably bili na lang ako ng K&N na filter tapos kabitan ko na lang ng cold air intake pipe. but where am going to buy those pipes (besides PVC pipes), how much, and does K&N or Simota sells cold air intake pipes individually dito sa 'Pinas???
    i heard someone telling me na may Iceman imitation daw. meron ba nun?
    anyone?
    thanks in advance....
    Aug 2004
    #45
    di ko maintindihan kung bakit reset pa ng ecu?? ecu is used sa mga sensors. wala naman sensor sa air filter nasa throttle body naman.
    Aug 2004
    #46
    No problem with using Simota as a CAI, but custom pipes that long cost $$$. Maybe 4-5 thousand at eRL on P.Tuazon (by Chocolate House)
    mojako, interesting yung article, pero K&N panel versus simota cone... syempre panalo Simota... more interesting kung K&N cone versus Simota cone... The margine will be the same in the opposite direction.
    yan_168, most EFI cars have a Mass Air Flow/Pressure sensor right behind the filter.
    And usually, you don't have to reset the ECU... it will work just fine... or if it doesn't, it will adapt in a few hours.
    #47
    eh sir paano naman dun sa carb ang auto meron din bang air filters for carb ang K&n?
    #48
    yup meron din sa pagkakaalam ko :D
    Aug 2004
    #49
    guys, question. if a car's engine is efi and you want to replace the stock filter with an aftermarket type, do you have to reset the ecu? if so, how do i do this?
    thanks in advance!
    ---- hmmm, ngayon ko lang narining to ah. 2 beses na kasi ako nagpalit ng filter. dati simota then after few months k&n na. basta pag kabit start na kaagad. wala naman ako naexperience na sira or ano. mag2years na rin yung k&n sa kotse ko. ok pa rin hangang ngayon. ang mumura ng k&n nyo ah.hehe san nyo nabibili yun? yung akin kasi 4,200 mas mahaba pa siya sa regular type. filter lang yun wala pa tube. yung tube ko is simota.
    Aug 2006
    #50
    gud day!!mag kano ba racing filter ng toyota corolla gli 94 model? pls reply asap tnx
Simota Intake / Air Filters
