Results 11 to 20 of 31
October 7th, 2017 10:17 PM #11
But then its from the UK but I am assuming Shell worldwide has same standards given such a global company would impose some common standards. But then if you are from Pilipinas Shell and if you say so then I concede...
V-Power Nitro + Diesel has special detergents inside that break up deposits, allowing the engine's injectors to spray freely (like a fresh new watering can). As the fuel travels through the injectors, it picks up the deposits and cleans them out, restoring the injectors, giving you an optimised fuel spray pattern and thus better combustion.
V Power Nitro+ Diesel also has a higher cetane rating (or combustion speed) than some ordinary diesel. This higher rating (an inverse of the octane number in petrol) means it tends to produce less soot during combustion, minimising the likelihood of your injectors being blocked again once cleaned. Any newly-removed soot is burnt as part of the combustion process and ejected via the exhausts.
October 7th, 2017 10:22 PM #12
October 7th, 2017 10:22 PM #13
October 7th, 2017 10:25 PM #14
I guess same arguments can be said for petrol too with those higher RON fuels. I mean I too can't feel the difference with Petron XCS (95) and their Euro 4 100octane on my Lexus IS if meron man. Much less even on a Yaris. Depends na din what car you tested it if it would make a difference or not...
In any case even the fuelsave one would meet the minimum requirements of all diesel cars being sold here...
October 7th, 2017 10:42 PM #15
No, PSPC's fuel isn't exactly the same as what the UK offers. Fuel configs are different per market.
Local Shell base fuel comes from different sources - some from Shell's Tabangao refinery, some from Petron's Limay refinery, and so on. But what's common among all of them is that FuelSave and V-Power diesel both come from the same base fuel and the differentiation comes from the additives used.
Petron XCS has a different base fuel from Petron Blaze (similar case with FuelSave 91 and VPower 95 and VPower Racing 97). Separate tanks in the depot, different base fuel RON ratings, different additives as well.
October 7th, 2017 10:50 PM #16
Jut,
What can you say about Caltex' Diesel fuel with TechronD? They don't sell any other tier.
If you compare it to Shell and Petron's offerings, which tier does Caltex' Diesel go up against?
October 7th, 2017 10:58 PM #17
Pricing is artificial. The difference in additives for FuelSave and V-Power is much less than the P2.50/L premium.
It's not 100% diesel. For one, all local fuels need 2% CME. Then there's the additives for FuelSave as well. Production cost is pretty much the same for FuelSave and V-Power.
October 8th, 2017 01:17 AM #18
- May 2017
- 18
October 9th, 2017 04:53 PM #19They are both the same fuel from the same refineries the only difference is that the V-Power has more additives in it that's all.
If your driving a modern vehicle then use V-Power it will help your fuel injectors but only in the long run.
And buy fuel from a clean place especially were they sell alot allot of fuel that way you won't be buying old fuel that's been in the ranks too long.
Sent from my SM-J510GN using Tsikot Forums mobile app
October 9th, 2017 06:02 PM #20
correct me if i am wrong but the only difference is that the 100 octane fuel will let you run at red line WITHOUT FEAR of engine knock and nothing more. higher octane rating does not equate to more power or better efficiency.
incidentally i filled up with vpd yesterday on the way to tagaytay ONLY BECAUSE my son wants the toy cars. i got 4. ass feel says same power as my regular cheaper and p2 discounted unioil diesel. and definitely lower mileage. my makati to sta rosa run registered 10.6 km/l at a leisurely 90-100 kph and the return trip sta rosa to makati run registered a bit higher 10.8 km/l (most probably due to lower air temp during the night). on unioil diesel this would have been 11.5 km/l at an average speed of 100 kph. trip computers don't suffer from placebo effect so there you go.Last edited by yebo; October 9th, 2017 at 06:06 PM.
How about 97 LXi?
Civic horsepower
