Sir speedyfix magkano po pa change ng atf ng Nissan Exalta granduer using royal purple atf? Yung all in price po, thanks![]()
Rp atf is 890/quart x3 and labor to replace it is 400.
5W30 srp is 600/quart
Gudpm po mga Bossing with Bighorn 4jg2 engine, ask lang po sana me ng ilang questions.
1. Gaano kadami po ba gear oil nito,
2, Gaano kadami din po ang ATF
3. Saan po ba nakakabili ng Baldwin Filters at ano po ba Code/Number ng fuel filter para sa 4jg2
Planning to change gear oil at ATF po this March with RP/Mobil lubricants (first time) since nabili yung Bighorn.
Reply With Quote Reply With Quote
Thats available already at speedyfix. It just supersedes the original one
got our oil changed to royal purple at speedyfix yesterday.
thanks sir. yung suzuki swift na red if you can remember hehe.
Mga sir san po kaya meron mabibilan Royal Purple Oil in south area? Pasay,Muntinlupa, Cavite area or maybe near Makati.
In makati you can buy it from split second. Just search for them online for the add but they are in the la fuerza compound in p. Tamo.
Friends, I'm scheduled for PMS. 5k kms. Montero sport. What type of RP oil can you recommend? May mga viscosity sya di ba? Thanks!
Royal purple recommends using full syn oil on diesels around 10k kms pa. So the engine is fully broken in. When u do switch, you can use 15w40.
I would suggest it after or during your 10k pms. In the meantime we have repsol or liquimoly mineral 15w40 oil in the shop.
I bought Royal Purple Oil from OLX seller. Then pa change oil ako kanina so after that napansin ko naging smooth yung takbo. I just wonder, yung nakalagay sa bottle hindi pala API certified ang RP oil but it says in the label "Can match or exceed API SL ratings".
As people say. good quality oil ang RP but why it is not API certified?
