Page 46 of 52 FirstFirst ... 36424344454647484950 ... LastLast
Results 901 to 920 of 1023
    Aug 2008
    #901
    Quote Originally Posted by rafmac View Post
    Drop off sa Robinson's galleria then cross edsa papunta poea side. Then take a bus or jeep baba Greenhills. Cross Ortigas to Wilson theb grab a shuttle hanggang mini stop. Then make a right to p guevarra its about a 5 minute walk from there
    Posted via Tsikot Mobile App
    Thanks sir raf. I appreciate it.
    Aug 2014
    #902
    Sir speedyfix magkano po pa change ng atf ng Nissan Exalta granduer using royal purple atf? Yung all in price po, thanks
    Oct 2014
    #903
    Nasa magkano po tamang price ng Royal Purple 5w30 ?
    Nov 2003
    #904
    Rp atf is 890/quart x3 and labor to replace it is 400.
    5W30 srp is 600/quart
    Apr 2010
    #905
    Gudpm po mga Bossing with Bighorn 4jg2 engine, ask lang po sana me ng ilang questions.
    1. Gaano kadami po ba gear oil nito,
    2, Gaano kadami din po ang ATF
    3. Saan po ba nakakabili ng Baldwin Filters at ano po ba Code/Number ng fuel filter para sa 4jg2
    Planning to change gear oil at ATF po this March with RP/Mobil lubricants (first time) since nabili yung Bighorn.
    Reply With Quote Reply With Quote
    Nov 2003
    #906
    3-4 qts for rear diff
    4-5qts for atf
    Apr 2010
    #907
    Thanks sir speedyfix
    Nov 2003
    #908
    Anytime!
    Oct 2013
    #909
    Royal Purple Duralec Super 15W40 for diesel engines. May nakapagtry na po ba nito? Kamusta siya compared sa regular Royal Purple 15W40 for diesel engines, yung una po. Thanks in advance.
    Nov 2003
    #910
    Thats available already at speedyfix. It just supersedes the original one
    Jan 2012
    #911
    got our oil changed to royal purple at speedyfix yesterday.
    thanks sir. yung suzuki swift na red if you can remember hehe.
    Nov 2003
    #912
    Yes i do. Thanks for passing by
    Oct 2014
    #913
    Mga sir san po kaya meron mabibilan Royal Purple Oil in south area? Pasay,Muntinlupa, Cavite area or maybe near Makati.
    Nov 2003
    #914
    In makati you can buy it from split second. Just search for them online for the add but they are in the la fuerza compound in p. Tamo.
    Nov 2014
    #915
    Friends, I'm scheduled for PMS. 5k kms. Montero sport. What type of RP oil can you recommend? May mga viscosity sya di ba? Thanks!
    Nov 2003
    #916
    Royal purple recommends using full syn oil on diesels around 10k kms pa. So the engine is fully broken in. When u do switch, you can use 15w40.
    Nov 2014
    #917
    Quote Originally Posted by speedyfix View Post
    Thank you speedyfix! Very informative! what you mean was I can not use royal purple for now because it only had 5k kms on it? What brand of oil you can recommens with 15w40? Thanks!
    Nov 2003
    #918
    I would suggest it after or during your 10k pms. In the meantime we have repsol or liquimoly mineral 15w40 oil in the shop.
    Oct 2014
    #919
    I bought Royal Purple Oil from OLX seller. Then pa change oil ako kanina so after that napansin ko naging smooth yung takbo. I just wonder, yung nakalagay sa bottle hindi pala API certified ang RP oil but it says in the label "Can match or exceed API SL ratings".
    As people say. good quality oil ang RP but why it is not API certified?
    Nov 2003
    #920
    You got the hps oil siguro not the api oil.
Royal Purple Oil
