Results 21 to 40 of 47
    Aug 2012
    *double post*
    Jun 2015
    nde ko alam kung maf sensor sira ng sentra ko.. kaso pag umaandar ako tapos kelangan ko mag clutch dhil hi2nto eh nma2tay minsan ung mkina ko.. meron kyang kinalaman ung maf sensor ko? ok naman cya humatak.. help! tnx..
    Feb 2009
    Quote Originally Posted by aldrey View Post
    Your idle speed maybe too low.
    Change your keyboard
    palinis mo pa rin yung maf sensor mo.....but i think your issue has got to do with the electricals..... di ka naman erratic RPM diba?
    Dec 2007
    Quote Originally Posted by hotwifey37 View Post
    ano ba yun? sabi ng mamang mekaniko...papalitan daw sa car ko kase sira na...kalerky....di ko naman alam itsura nun....h
    hi maam, may I ask what car? and what was the problem with the car? maybe the maf sensor needs cleaning.
    Jun 2005
    .... and please before you clean the MAF sensor, type properly. sakit sa ulo magbasa!
    bawal text speak dito boss.
    Jun 2015
    Quote Originally Posted by sirkosero View Post
    Sorry sir.. hehe. tnx. yung rpm ko naglalaro lng sa 800 to 1000 depende sa aircon kung patay o bukas ung compressor.. pero minsan bumababa siya talaga ng 200.. sa maf sensor kaya un? pede ba talaga mag DIY sa paglilinis nun?
    meron ka pa ding text speak (yung tnx...).
    medyo consistent yung rpm mo, pero minsan bumababa..... while cleaning the MAF sensor is really recommended due to the dirty air that we have here in Manila, there may be other causes, like as I've said, electrical.
    kung bagito ka, don't attempt to do it DIY.... baka masira mo yung mismong MAF sensor. palinis mo na lang sa marunong na shop. normally costs 800 pesos, compared to the cost ng MAF sensor na pag nasira mo...
    Jun 2015
    Quote Originally Posted by 1D4LV View Post
    May ma irerecommend ka ba sir na shop? hinde ko kasi alam kung saan ako pwede magpalinis eh. by the way dito ako sa may alabang area.. baka nga din sa electrical kasi madame na modification. mejo loaded kasi sa sounds eh.
    alabang area.... dyan ako nagpapalinis sa servitek in front of concha cruz.
    Jun 2005
    naka aircon ka ba? kung naka patay ang aircon, nanginginig pa ba ang engine?
    probably vacuum leak yan
    check mo vacuum hoses pati idle up mo.
    anong sasakyan ba ito?
    Jun 2015
    pag nag automatic mamatay yung aircon niya sir minsan bigla bababa ang idle eh.. minsan naman hinde. nissan sentra super touring 97 model. try ko din pa check yung vacuum hoses niya sir.. thanks!
    Jun 2005
    pacheck mo servo boss. sakit ng sentra yun
    Jun 2015
    sige sir.. may shop ka bang alam na nag ccheck up ng servo? wala kasi ako mahanap na maayos na pedeng puntahan.. balik lang yung sakit na to after gawin eh..
    yan mga nissan may idle switch yan sa tps dapat ma iset ng tama
    Jun 2015
    Quote Originally Posted by t2erns View Post
    sir saan kaya ang location nun? hinde ako pamilyar sa nissan pa eh.. thanks!
    Feb 2009
    TPS of the '90's may have 4-5 terminals and has the idle switch. OBD II systems only have 3 terminals and don't have an idle switch
    kapag 2 connectors ng tps mo may idle switch (or closed throttle switch) makikita mo lang reading nito sa scanner.yun iba naman sa accelerator pedal position sensor, pero yan nissan mo wala pang app sensor,( sa mga throttle-by-wire lang meron).
    Jun 2014
    Sir san pwede mag palinis ng maf sensor? Nagpalinis kc ako sa casa ng throttle body tapos ndi daw nililinis un maf sensor. Ngaun masyado mataas rpm ko pag start ng kotse around 1.8-2rpm kaya tingin ko un reason kaya bumagsak fc ko. Area po sana from fairview to banawe. Also, do i need to bring electronic contact cleaner or merun na sila dun? Thanks
    Jun 2015
    Quote Originally Posted by _incubus19 View Post
    sir try mu s servitek.. nde ko lng alam kung anu pnkmlapit senyo.
maf sensor?
