Page 48 of 52 FirstFirst ... 38444546474849505152 LastLast
Results 941 to 960 of 1023
    #941
    sir anong royal purple oil marecommend mo for tucson 2011 gas? & for 10.5 gen altis?
    Nov 2003
    #942
    both can use 5w30 or 10w30 oil
    #943
    *speedyfix,thanks sir
    Jun 2004
    #944
    What's a good oil for Mits Mirage 1K PMS?
    Nov 2003
    #945
    Quote Originally Posted by venerzky View Post
    5w30 or 10w30
    Jun 2004
    #946
    Quote Originally Posted by speedyfix View Post
    5w30 or 10w30
    Yung color ba talaga ng langis is dark purple/violet? And yung plastic bottle ay hindi sealed foil? Ganun ba talaga. Thanks.
    Nov 2003
    #947
    yes oil is purple.
    no foil seal.
    #948
    sir what viscosity po for vios 2NZ-FE 1.3 105,000km
    Nov 2003
    #949
    you should be fine using either 10w30 or 10w40
    Apr 2009
    #950
    Meron po bang authorized reseller/changeoil ng RP sa Fairview or malapit? tia
    Nov 2003
    #951
    Quote Originally Posted by Densker View Post
    none sorry!
    Apr 2011
    #952
    *speedyfix, do you ship to provincial destinations? Do you have 5W30 ACEA B4 CI-4 for Accent CRDI?
    Nov 2003
    #953
    Quote Originally Posted by airolynx View Post
    sorry we don't ship the oil.
    #954
    What oil for 2010 civic fd 1.8s 53k mileage?
    Nov 2003
    #955
    5w30 or 10w30
    Apr 2016
    #956
    washburn, that's great news!
    shadow, thanks for the updates! sulit yung syncromax right? super recommended ko yun for all honda manual tranny's.
    wrcastro_ph, the reason malapot yung motul is because it has lots of detergent properties kaya kuhang kuha yung dumi. better to keep the dirt in the oil but it also gets "malapot" earlier. kung at least once a year or every 10k kms naman palitan it should be ok.
    *speedy.... sir about to chnage tbelt, tensioner, cam/crank oil seals at change oil & trans oil M/T na rin. 96 vti 230kms. Ok lang ba saksakan ko ng RP 10W40 engine? Ive read dto on a diff thread na older civics uses engine oil for trans oil. Anu advise nyo sir sa trans oil? synchromax? may other varieties/grade/visco ba yan or isa lang sya? TIA
    Nov 2003
    #957
    Quote Originally Posted by Oste View Post
    10w40 is perfect for the engine. for the transmission you can use 10w30.
    Apr 2016
    #958
    sa engine bale ok po ba ung valvoline dura blend syntethis blend 10w40?
    transmission: 10w30 regular or synthetic, alin po dyan mas smooth shifting and mas advisable sa to lessen wear & tear? or i synchromax ko na? Sensha na medyo maalaga lng sa car sir hehe. TIA
    Nov 2003
    #959
    we're out of stock of synchromax, i don't know about valvoline. we don't carry that.
    Apr 2016
    #960
    ok thanks sir. Pero sa transmission any brand engine oil bsta 10w30 good sya sir?
Royal Purple Oil
