yup you can bring your own filter5w30 is available. sarado kami sunday. mon-sat 9am-6pm lang kami open
Hello sir Migs, just bought a gen 2 crv with 81Tkm on the ODO, and I would like to change the fluids to RP what do you recommend for the ff.
1. Engine Oil (full syn)
2. AT Transmission Oil
pa tune up ko na din. Mga how much kaya aabutin?
Thanks!
hi, you can use 10w30 RP oil for the engine and RP max atf for the transmission. you can me or my staff in the shop at 7226117 for the pricing so it's not discussed here kasi medyo o.t. na.
thanks!![]()
most of the time we use the service manual to determine which viscosity to use for different cars. it will provide you with a jump-off point to know what viscosities are suitable for your engine and normally there is a range of viscosities depending on the climate.
we sometimes adjust viscosity though depending on age or usage of the car. for example if the engine has over 200,000 kms on it, we may opt to go one range up in terms of viscosity just to give it a bit of extra protection. we also adjust if the car is heavily modified and is used heavily for the track etc...
sorry that's not a difinitive answer but that's basically how i decide what's best to use![]()
