Page 35 of 52 FirstFirst ... 2531323334353637383945 ... LastLast
Results 681 to 700 of 1023
    #681
    Quote Originally Posted by speedyfix View Post
    hi, you can use 10w30 RP oil for the engine and RP max atf for the transmission. you can me or my staff in the shop at 7226117 for the pricing so it's not discussed here kasi medyo o.t. na.
    thanks!
    ok thanks, I'll call and visit your shop na lang thanks!
    Nov 2003
    #682
    ok thanks!
    Sep 2011
    #683
    I don't know whether this was covered before, didn't find it in the previous pages, but why does RP recommends a diesel engine to travel 8,000 to 10,000 miles ( approx 12-16 thou Kms.) before using it? (as stated in their website) Planning to use a synthetic oil during my 1K PMS, as this is the recommendation by the service dept of mitsu, and I am highly considering RP until I saw that recommendation in their website.
    What would be a good synthetic alternative to RP in a new engine? I am not inclined in using a mineral based oil for now.
    Nov 2003
    #684
    this is because diesel engines take a long time to break in. and using synthetic oil will cause it to take even longer. the best time to use synthetic oil is when the engine is fully broken in na.
    Sep 2011
    #685
    So the 1000 kms na break in period po ng diesel engines is not enough or do I need to use a non synthetic to hasten the break in period? Sorry for the noob and OT question, but won't it be better that the break in period is longer so that the "new condition" of the engine is also prolonged? Are there disadvantages of a prolonged break in period of an engine? The only disadvantage I can think of is that you can't drive your vehicle hard because it is not yet fully broken in.
    Nov 2003
    #686
    you want the breakin to be done as fast as possible so that the engine becomes efficient sooner. mineral oil with quick successions of oil changes is the best thing when a diesel engine is new.
    Aug 2005
    #687
    Sir magkano po charge pag change oil honda crv 2.0? Alam ko di na kasama sa promo. Magkano pa po dadagdag s 2,700?
    Nov 2003
    #688
    you'll have to add 600 for the extra quart of oil. so 3300 na
    #689
    question lang, what viscosity should i use, bighorn ubs69 almost 200thou kms on odo.. thanks..
    Nov 2003
    #690
    We normally use 15w40 on all diesel engines.
    #691
    sir, what viscosity would you suggest on a vvt-i innova with 30,000 km?
    thanks!
    Nov 2003
    #692
    use 10w30 for a gas innova and 15w40 for a diesel one.
    #693
    wow that was fast.
    will drop by your shop probably this sat.
    thanks!
    Nov 2003
    #694
    ok thanks! see you!
    Jul 2006
    #695
    On my way to Speedyfix for my 5k maintenance on my Lancer EX! it'll be my first time to try Royal Purple.
    Nov 2003
    #696
    thanks for dropping by!
    Jul 2011
    #697
    sir speedyfix may tanong po ako tungkol sa royal purple. ano po ba ang recommended change interval ng fully synthetic oil? 12mos or 10K which ever comes first? TIA.
    Nov 2003
    #698
    for gas engines 1year or 10k kms is fine.
    Jun 2010
    #699
    may alam po ba kayong shop near laspiņas city? and what oil should i use on my 1996 nissan vanette?
    Nov 2003
    #700
    you can use a 10w40. contact bong from escapezone coz he's in the south. 09287920168 or 09223038200
Royal Purple Oil
