Page 34 of 52 FirstFirst ... 2430313233343536373844 ... LastLast
Results 661 to 680 of 1023
    May 2011
    #661
    sir speedyfix,
    kasama ba sa promotion ang change oil ng 95 GLXi (4G92)?
    Nov 2003
    #662
    yup kasama sa promo yan
    #663
    brod if ever mag pa change oil ba sa inyo honda city type z meron na kayong oil filrter dyan dyan or kami na bibili at dadalhin pag punta dyan? or kasama na sya pag nag pa change oil sa inyo?
    Nov 2003
    #664
    yup we have the filter. it's included na in the promo.
    thanks!
    May 2011
    #665
    Quote Originally Posted by speedyfix View Post
    thank you migs, dadaan ako paguwi ko ha.
    Nov 2003
    #666
    ok seeya!
    Dec 2008
    #667
    Sir papAno po ba punta dyan sa shop nyo pag commute Lang. Saan po ba sasakay pag galing mrt pasay. Lumipat na po kasi kayo ng shop e
    Nov 2003
    #668
    you can check the google map at Speedyfix Manila
    Aug 2011
    #669
    sir migs! been reading good comments about your shop, i actually sent an estimate sa speedyfix site, nahihirapan kasi ako sir maghanap ng trusted shop na hindi overpriced at manloloko (bad experience) medyo newbie pa kasi pagdating sa kotse kaya kahit sa laguna pa ako manggagaling, mukhang worth it naman ibyahe sa shop nyo
    Nov 2003
    #670
    thanks bro seeya when you pass by the shop!
    Dec 2007
    #671
    *speedyfix, sir meron na ba kayo oil filter para sa chevy spark?
    Nov 2003
    #672
    wala ako, i'll need the sample in order to get it for you.
    Oct 2009
    #673
    Migs,
    Can I bring my own oil filter? The last time I went to your shop it's not yet available so one of your co-worker need to go at supplier pa. Also, meron pa 5w30? Baka daan ako bukas or sa sunday. Thanks!
    Nov 2003
    #674
    yup you can bring your own filter 5w30 is available. sarado kami sunday. mon-sat 9am-6pm lang kami open
    Oct 2009
    #675
    Thanks. Will meet you again on the next 5Kms. Dalhin ko na lang mga natirang oil :-)
    Nov 2003
    #676
    ok thanks thanks!
    #677
    Hello sir Migs, just bought a gen 2 crv with 81Tkm on the ODO, and I would like to change the fluids to RP what do you recommend for the ff.
    1. Engine Oil (full syn)
    2. AT Transmission Oil
    pa tune up ko na din. Mga how much kaya aabutin?
    Thanks!
    Nov 2003
    #678
    hi, you can use 10w30 RP oil for the engine and RP max atf for the transmission. you can me or my staff in the shop at 7226117 for the pricing so it's not discussed here kasi medyo o.t. na.
    thanks!
    #679
    sir migs, how do you determine if 10w40 or 10w30 to use?
    Nov 2003
    #680
    most of the time we use the service manual to determine which viscosity to use for different cars. it will provide you with a jump-off point to know what viscosities are suitable for your engine and normally there is a range of viscosities depending on the climate.
    we sometimes adjust viscosity though depending on age or usage of the car. for example if the engine has over 200,000 kms on it, we may opt to go one range up in terms of viscosity just to give it a bit of extra protection. we also adjust if the car is heavily modified and is used heavily for the track etc...
    sorry that's not a difinitive answer but that's basically how i decide what's best to use
Royal Purple Oil
