Page 31 of 52 FirstFirst ... 2127282930313233343541 ... LastLast
Results 601 to 620 of 1023
    Nov 2003
    #601
    oil frothing, etc.
    no need na to ask about other bad effects, just have the level drained until normal at the earliest time possible.
    #602
    di naman po ako nagexcess ng oil, tinatanong ko lang just in case.. iba na rin cyempre pag alam mo na ang effect. thanks
    Nov 2003
    #603
    ahhh.... ok.
    #604
    so ano po yung mga bad effects?
    #605
    Quote Originally Posted by simarun View Post
    ito o, sinagot ka na sa taas.
    Quote Originally Posted by speedyfix View Post
    oil frothing, etc.
    Nov 2003
    #606
    you can also google it just as easily as asking here:
    http://wiki.answers.com/Q/What_damag...motor_with_oil
    #607
    wala naman kung konti yung over. pero have it drained at the earliest time available.
    kung marami sobra there are a lot of bad effects.
    i mean yung "lot of bad effects" aside from frothing.
    thanks anyway
    Aug 2010
    #608
    Sir Speedy, I'm planning to have my tune up in your shop this coming weekend. Due to strict budget, I'm having a hard time affording CASA services. Sorry if the following/some of my queries were asked already:
    1.Reservation po ba or first come first served ang service?
    2. What time nagbubukas ang shop?
    2. What Royal Purple oil is appropriate for my 1.5G Toyota Vios MT? Mauubos ko po ba yung isang bote during tune up?
    3. Are you capable or do you also check valve clearance, clean O2 sensor, MAF sensor, clean throttle body, adjust timing chain ng VIOS during tune-up? May enough equipments ba kayo to do and evaluate if these things are in there correct settings? (that's why I can't rule out CASA because they have the technology to check them)
    4. May I opt to choose what spark plugs to install or standard spark plugs na po yung offered sa tune up service niyo? (Iridium spark plugs I prefer)
    5. Is there a tune up promo right now?
    6. How much po aabutin kung sakali?
    And btw, 26k kms+ na yung odometer ng car ko. 3rd tune up since I bought the car. Failed to bring it regularly for tune up due to budget constraints. Lagpas 10k kms na siya ngayon since the last tune up, Toyota fully synthetic ang currently nakalagay.
    Thank you.
    Nov 2003
    #609
    please see my reply below:
    Quote Originally Posted by Lyle View Post
    1.Reservation po ba or first come first served ang service? -- it's first come first served
    2. What time nagbubukas ang shop? -- we're open from 9-6 mon-sat
    2. What Royal Purple oil is appropriate for my 1.5G Toyota Vios MT? Mauubos ko po ba yung isang bote during tune up? -- you can use a 10w30 oil. you'll need around 4 quarts which is included sa promo
    3. Are you capable or do you also check valve clearance, clean O2 sensor, MAF sensor, clean throttle body, adjust timing chain ng VIOS during tune-up? May enough equipments ba kayo to do and evaluate if these things are in there correct settings? (that's why I can't rule out CASA because they have the technology to check them) -- your valve clearance is shim based so no need to adjust it. you don't ever have to clean an o2 sensor. we can clean the maf and throttle. you don't adjust the timing chain or tension, this is done automatically by a hydraulic tensioner.
    4. May I opt to choose what spark plugs to install or standard spark plugs na po yung offered sa tune up service niyo? (Iridium spark plugs I prefer) -- you can choose regular or iridiums but the iridiums are more expensive. we have both available in the shop.
    5. Is there a tune up promo right now? -- no there's none.
    6. How much po aabutin kung sakali? -- you may call the shop for the pricing. this is not the correct place to ask for pricing since it is primarily here to discuss royal purple oil.
    And btw, 26k kms+ na yung odometer ng car ko. 3rd tune up since I bought the car. Failed to bring it regularly for tune up due to budget constraints. Lagpas 10k kms na siya ngayon since the last tune up, Toyota fully synthetic ang currently nakalagay. -- you may want to flush the oil before changing it since your engine, as well as most modern toyota engines are known to have sludging problems if oil changes are not done on time.
    Thank you.
    thanks,
    migs
    Aug 2010
    #610
    Sir migs, thank you for the early reply. As for my question #3, may nagrarattle po kasi kapag nagaaccelerate during 2.5k rpm and up. Don't know if the culprit is the timing chain or bearing. Tapos maingay yung tunog ng engine kapag naaccelerate, parang butas na tambutso yung tunog, may nagsabi sakin na baka sa valve clearance daw. Anyway, dalhin ko nalang din po dyan sa shop. Thanks po ulit.
    Nov 2003
    #611
    it's almost impossible for the valve clearance to be off at your milage. it's probably a bad batch of gas or the fact that you've delayed your oil change for this long.
    Apr 2011
    #612
    Sir Migs,
    Just got my 2011 hyundai mt accent last May 18. I will be having my 1k kms PMS at the case soon . What RP would be best? Likewise, do you already have authorized dealers of RP in north Luzon? I'm from Dagupan City, however, kung wala dealer malapit sa amin, I plan to purchase it there when i visit mmla 1st week of June.
    Thanks in advance!
    Nov 2003
    #613
    hi, the viscosity will depend on the engine. for a gas engine i'd go straight for the 5w30. for diesels, i'd wait till 10k kms before using the 15w40 oil.
    you can always order RP from PhilShopping.com | Online Shopping Philippines | Online Shopping and it'll be shipped to your door
    Apr 2010
    #614
    Sir Migs!
    see you on Monday! going to have my scheduled 35,000 km change oil with Royal Purple...
    can you PM me din ulit your recommended Royal Purple Differential and Transmission Oil change price? sorry.. nabura ko yung last message mo eh.. kaka hiya tuloy... ahihihihi!
    for APV Type 1 - G16A engine (old vitara engine siya)
    Para may dalang budget na ko for monday. tsaka stickers ha? hehehe...
    Nov 2003
    #615
    ok bro seeya! yung atf ng rp is 700/quart. you need mga 3-4. labor is 400. the max gear rear diff fluid is 800/quart and mga 2 kelangan mo. labor is the same as atf
    thanks!
    #616
    Thank you for this update on online order. It would be a great help to us in the south to use the RP product.
    Nov 2003
    #617
    glad i can help. cheaper pa to order online than it is to pay for gas and the toll. hehe!
    Nov 2003
    #618
    #619
    i'm further down south. Davao, Mindanao.
    Nov 2003
    #620
    try to get in touch with them and see if they can deliver to you. who knows...
Royal Purple Oil
