oil frothing, etc.
no need na to ask about other bad effects, just have the level drained until normal at the earliest time possible.
oil frothing, etc.
di naman po ako nagexcess ng oil, tinatanong ko lang just in case.. iba na rin cyempre pag alam mo na ang effect. thanks
you can also google it just as easily as asking here:
http://wiki.answers.com/Q/What_damag...motor_with_oil
Sir Speedy, I'm planning to have my tune up in your shop this coming weekend. Due to strict budget, I'm having a hard time affording CASA services. Sorry if the following/some of my queries were asked already:
1.Reservation po ba or first come first served ang service?
2. What time nagbubukas ang shop?
2. What Royal Purple oil is appropriate for my 1.5G Toyota Vios MT? Mauubos ko po ba yung isang bote during tune up?
3. Are you capable or do you also check valve clearance, clean O2 sensor, MAF sensor, clean throttle body, adjust timing chain ng VIOS during tune-up? May enough equipments ba kayo to do and evaluate if these things are in there correct settings? (that's why I can't rule out CASA because they have the technology to check them)
4. May I opt to choose what spark plugs to install or standard spark plugs na po yung offered sa tune up service niyo? (Iridium spark plugs I prefer)
5. Is there a tune up promo right now?
6. How much po aabutin kung sakali?
And btw, 26k kms+ na yung odometer ng car ko. 3rd tune up since I bought the car. Failed to bring it regularly for tune up due to budget constraints. Lagpas 10k kms na siya ngayon since the last tune up, Toyota fully synthetic ang currently nakalagay.
Thank you.
Sir migs, thank you for the early reply. As for my question #3, may nagrarattle po kasi kapag nagaaccelerate during 2.5k rpm and up. Don't know if the culprit is the timing chain or bearing. Tapos maingay yung tunog ng engine kapag naaccelerate, parang butas na tambutso yung tunog, may nagsabi sakin na baka sa valve clearance daw. Anyway, dalhin ko nalang din po dyan sa shop. Thanks po ulit.
it's almost impossible for the valve clearance to be off at your milage. it's probably a bad batch of gas or the fact that you've delayed your oil change for this long.
Sir Migs,
Just got my 2011 hyundai mt accent last May 18. I will be having my 1k kms PMS at the case soon . What RP would be best? Likewise, do you already have authorized dealers of RP in north Luzon? I'm from Dagupan City, however, kung wala dealer malapit sa amin, I plan to purchase it there when i visit mmla 1st week of June.
Thanks in advance!
hi, the viscosity will depend on the engine. for a gas engine i'd go straight for the 5w30. for diesels, i'd wait till 10k kms before using the 15w40 oil.
you can always order RP from PhilShopping.com | Online Shopping Philippines | Online Shopping and it'll be shipped to your door![]()
Sir Migs!
see you on Monday! going to have my scheduled 35,000 km change oil with Royal Purple...
can you PM me din ulit your recommended Royal Purple Differential and Transmission Oil change price? sorry.. nabura ko yung last message mo eh.. kaka hiya tuloy... ahihihihi!
for APV Type 1 - G16A engine (old vitara engine siya)
Para may dalang budget na ko for monday. tsaka stickers ha? hehehe...
ok bro seeya! yung atf ng rp is 700/quart. you need mga 3-4. labor is 400. the max gear rear diff fluid is 800/quart and mga 2 kelangan mo. labor is the same as atf
thanks!
glad i can help. cheaper pa to order online than it is to pay for gas and the toll. hehe!
try to get in touch with them and see if they can deliver to you. who knows...
