please see my reply below:
Quote Originally Posted by Lyle View Post
Sir Speedy, I'm planning to have my tune up in your shop this coming weekend. Due to strict budget, I'm having a hard time affording CASA services. Sorry if the following/some of my queries were asked already:
1.Reservation po ba or first come first served ang service? -- it's first come first served
2. What time nagbubukas ang shop? -- we're open from 9-6 mon-sat
2. What Royal Purple oil is appropriate for my 1.5G Toyota Vios MT? Mauubos ko po ba yung isang bote during tune up? -- you can use a 10w30 oil. you'll need around 4 quarts which is included sa promo
3. Are you capable or do you also check valve clearance, clean O2 sensor, MAF sensor, clean throttle body, adjust timing chain ng VIOS during tune-up? May enough equipments ba kayo to do and evaluate if these things are in there correct settings? (that's why I can't rule out CASA because they have the technology to check them) -- your valve clearance is shim based so no need to adjust it. you don't ever have to clean an o2 sensor. we can clean the maf and throttle. you don't adjust the timing chain or tension, this is done automatically by a hydraulic tensioner.
4. May I opt to choose what spark plugs to install or standard spark plugs na po yung offered sa tune up service niyo? (Iridium spark plugs I prefer) -- you can choose regular or iridiums but the iridiums are more expensive. we have both available in the shop.
5. Is there a tune up promo right now? -- no there's none.
6. How much po aabutin kung sakali? -- you may call the shop for the pricing. this is not the correct place to ask for pricing since it is primarily here to discuss royal purple oil.
And btw, 26k kms+ na yung odometer ng car ko. 3rd tune up since I bought the car. Failed to bring it regularly for tune up due to budget constraints. Lagpas 10k kms na siya ngayon since the last tune up, Toyota fully synthetic ang currently nakalagay. -- you may want to flush the oil before changing it since your engine, as well as most modern toyota engines are known to have sludging problems if oil changes are not done on time.
Thank you.
thanks,
migs
