Results 1 to 6 of 6
November 18th, 2014 12:29 AM #1
Hi guys,
May oil leak yun ilalim ng sasakyan kada alis sa parking, sabi ng mekaniko na nag check, may tagas daw yun rear engine oil seal. Sabi kasi kelangan ibaba yun transmission para mapalitan. Hindi kasi ako comfortable sa ganun at first time ko na experience ito. Kelangan ba talaga ibaba yun transmission?
November 18th, 2014 09:05 AM #2
If you have Chevy V8, no. Most engines, yes and as a might as well a clutch job
November 18th, 2014 09:14 AM #3
- Jul 2009
- 153
November 18th, 2014 06:35 PM #4Kalas propeller shaft (if rear wheel drive) or drive shaft (if front wheel drive), kalas transmission support, baba transmission, kalasin clutch assembly, kalasin flywheel para makarating dun sa oil seal ng crankshaft. Palinis and pa-check mo na din condition ng clutch lining and release bearing kung ok pa or much better, palitan mo na din para makamenos ka sa labor.
whew, pinawisan ako sa pag-type!!!
November 19th, 2014 11:21 PM #5
[QUOTE=Wishing;2426996]Kalas propeller shaft (if rear wheel drive) or drive shaft (if front wheel drive), kalas transmission support, baba transmission, kalasin clutch assembly, kalasin flywheel para makarating dun sa oil seal ng crankshaft. Palinis and pa-check mo na din condition ng clutch lining and release bearing kung ok pa or much better, palitan mo na din para makamenos ka sa labor.
whew, pinawisan ako sa pag-type!!![/
salamat, Wishing. pasensya ka na hahaha kelangan ko na ba agad magpalit ng ATF? o pwede next time na? balak ko kasi ipa dialysis treatment yun ATF. medyo lampas na pala sa budget ko yun labor at parts nito.
- May 2018
- 1
August 4th, 2019 02:27 AM #6
Naglabas daw Ng delicą 4 x 4 Ang Mitsubishi ph Ng mid 2000s ? Is that true?
Mitsubishi Philippines
