Kalas propeller shaft (if rear wheel drive) or drive shaft (if front wheel drive), kalas transmission support, baba transmission, kalasin clutch assembly, kalasin flywheel para makarating dun sa oil seal ng crankshaft. Palinis and pa-check mo na din condition ng clutch lining and release bearing kung ok pa or much better, palitan mo na din para makamenos ka sa labor.
whew, pinawisan ako sa pag-type!!!
