Results 1 to 6 of 6
    May 2013
    Hi guys,
    May oil leak yun ilalim ng sasakyan kada alis sa parking, sabi ng mekaniko na nag check, may tagas daw yun rear engine oil seal. Sabi kasi kelangan ibaba yun transmission para mapalitan. Hindi kasi ako comfortable sa ganun at first time ko na experience ito. Kelangan ba talaga ibaba yun transmission?
    Feb 2009
    If you have Chevy V8, no. Most engines, yes and as a might as well a clutch job
    May 2013
    thanks. that explains the hefty labor fee of 3K.
    Kalas propeller shaft (if rear wheel drive) or drive shaft (if front wheel drive), kalas transmission support, baba transmission, kalasin clutch assembly, kalasin flywheel para makarating dun sa oil seal ng crankshaft. Palinis and pa-check mo na din condition ng clutch lining and release bearing kung ok pa or much better, palitan mo na din para makamenos ka sa labor.
    whew, pinawisan ako sa pag-type!!!
    May 2013
    [QUOTE=Wishing;2426996]Kalas propeller shaft (if rear wheel drive) or drive shaft (if front wheel drive), kalas transmission support, baba transmission, kalasin clutch assembly, kalasin flywheel para makarating dun sa oil seal ng crankshaft. Palinis and pa-check mo na din condition ng clutch lining and release bearing kung ok pa or much better, palitan mo na din para makamenos ka sa labor.
    whew, pinawisan ako sa pag-type!!![/
    salamat, Wishing. pasensya ka na hahaha kelangan ko na ba agad magpalit ng ATF? o pwede next time na? balak ko kasi ipa dialysis treatment yun ATF. medyo lampas na pala sa budget ko yun labor at parts nito.
    May 2018
    [QUOTE=gutz_3110;2427521]
    Quote Originally Posted by Wishing View Post
    PTA>> may idea po ba kayo ano part number ng crankshaft oil seal ng honda civic 99 model, may leak din kasi jan.. nag palit na oil seal kaso may leak pa dn baka need ng OEM na po.. salamat...
Replacement: Rear Engine Oil Seal
