^ Yep. And Toyota uses a special tool to remove the canister so when you have service done elsewhere, the mechanic should know how to properly unscrew it.
I hope better aftermarket elements will become available just as well. The o-ring (seen next to the filter) is also replaced every oil change.
that kinda sucks. limits you from using other after market filters like baldwin or FG.
You are stuck with Toyota OEM for now I guess till there are after market options.
