Better than a standard single filter system, but then again if your using low quality filters that can't filter efficiency then the difference is not much difference. But in theory it should work. The TD42's that do have the dual system do use a bypass system, They also have two different filter threads one is 3/4 16 and the other is 1-12UNF kinda weird. But I guess it keeps you from mixing up the full flow and the bypass filter.
One more thing: How about the pressure loss after passing through the dual filtration system? Is it still within the acceptable pressure readings?
No doubt bibili ako ng magandang klaseng filter kung may available. Magkano lang naman. Ang problema ay wala masyado kaya regular change na lang.
Mabuksan nga sa weekend yung Vic na gamit na sa bahay. I'll check the internals kung ano klaseng material ang ginamit.
VIC is Cellulose, They tend to dye there filter media for some reason could be a resign or something to strengthen it, I be curious to see some different ones cut open.
as a side note baldwin filters are available here in the Philippines. I use their oil and fuel filter.
Makes sure they are real Baldwin filters plenty of fakes in that part of the world.
Biggest thing to look for is.
Country of Origin - Baldwin manufactured filters are marked with the country of origin. Baldwin has manufacturing plants in the United States, the United Kingdom, Mexico, South Africa, Morroco and China. If it does not have this it's a fake just makes sure you getting what you paid for.
Other stuff.
Color
The color of a Baldwin spin-on filter may not be correct on a counterfeit filter. It may be close, but just not right.
Graphics
Graphics on the filters, including the logo, may be missing or incorrect. In the photo to the left, the counterfeit filter has 2 I's in Baldwin.
Components
A counterfeit filter may look right upon first glance, but upon closer examination, you may find major differences. Some places to look include:
Dimensions - The dimensions of the filter may not be the same as a genuine Baldwin filter.
Baseplate - The baseplate may look different or be made from a different material than that used by Baldwin.
Media Packs - Counterfeit media packs often have an obviously lower pleat count than Baldwin. In addition, the pleats may be deformed.
Gaskets - Both internal and external gaskets may look different or be made from a different material than that used by Baldwin
Real Baldwin box.
Baldwin shop is Volmax - I don't have their number right now. I'll give it out on Monday. The shop is on s padilla in Manila.
Wix filters on the other hand is sold Superior Motors 3741737. It is near Quezon Ave.
from what I have researched these are the two consistent high quality filters even in the US
OT: hi dvldoc. I have a PM for you regarding alcohol injection that I got from you years ago.
Wix is a excellent brand, actually one of the better over the counter filters. Just make sure it's the real deal.
WIX Box should look like this. and if it does not say WIX Corporation, Gastonia N. C. made in USA on the back it's not the real deal.
The other countries of production will be these. If no country of origin then it's not the real deal.
Mexico
Ukraine
Venezuela
Brazil
Poland
If they come in a plain white box with a Wix label stuck on, are white in color and they come in shrink warp plastic. They have the Wix part number stenciled in blue on the filter it's not the real deal.
Two style boxes
As you can see they are high quality filter, I got a bunch myself, If I see them on sale I pick them up.
What do you think guys? Are this legit dealers?
Sulit Ad ID #3866607 - perkins oil filter and other brands daw
Sulit Ad ID #4884543 - For your inquiries please contact Don:
MP: +639232067202
Email: allmakesasia3*yahoo.com
donald*allmakesworld.com
And what's the Baldwin distributors address in Cebu?
Fasten your seatbelt! Or else...Driven To Thrill!
