Results 1 to 13 of 13
    Dec 2009
    Planning to buy OBD Scanner na OBD1 / OBD2 compliant.
    Please recommend brand and specific model that you
    have used or if you have any idea ano magandang bilhin.
    If I am going to buy OBD2 scanner then buy a OBD1 / OBD2
    adapter, please suggest the brand and model as well.
    I will use it for Honda OBD1 ECU and for 2015 Montero / 2015 MUX.
    Your input is highly appreciated!
    Quote Originally Posted by cyclops_23 View Post
    halos lahat naman ng obd2 scanner will easily read honda and mitsubishi isuzu protocols. cheap generic ones will do fine even the blue tooth based dongles will work. Branded ones autel, inova, actron if you like some can reset abs srs too but they are not cheap especially if you are not using them on a regular basis. kun DIY lang you do not have to spend that much. personally hinahanap ko yun nag babasa din ng toyota IMV vehicles. Aside from professional grade obd scanners ( read: super expensive) wala pa ako mahanap nag babasa ng toyota IMV(diesel innova hilux fortuner hiace) . mga sedan cuv gas suv nila no problem basahin. I've borrowed a midrange autel maxi diag elite di din mabasa toyota imv.
    Jan 2009
    ... Aside from professional grade obd scanners ( read: super expensive) wala pa ako mahanap nag babasa ng toyota IMV(diesel innova hilux fortuner hiace) . mga sedan cuv gas suv nila no problem basahin. I've borrowed a midrange autel maxi diag elite di din mabasa toyota imv.
    It has an OBD-II ‘style’ DLC connector but it doesn’t seem to be using the standard OBD-II signaling protocol. None of my OBD-II scanners (ScanGaugeII and UltraGauge) can read anything.
    So I got from eBay Toyota’s own PC software, Techstream. It comes with an OBD-II-to-USB dongle and it's not expensive (ok, it's not what you'll call a 'legit' copy either). Though, you will need a laptop and a bit of skill to use it and in case it wasn't obvious enough, this is a serious troubleshooting tool and it's not meant to be installed semi-permanently like a ScanGaugeII, et al.
    I was able to clear a stored DTC and monitored a few other things during one of my commute some years back. That was it.
    ito cheap and totoong ver 1.5 from ancel
    https://shopee.ph/product/159414345/2381041520
    meron ako nakita gamit ni jeepdoctor, nasa 10k din yata
    yun yata nasa cart ko noon, tapos di ko tinuloy LOL
    alin video dun sir? puro honda crv scan niya. di ko makita yun toyota.
    my bad ...
    eto pala gamit nya .. di gumana innova
    ₱10,999.00 -39% | FOXWELL NT624 Elite Full System OBD2 Scanner Engine ABS Airbag ESP with Oil/ EPB Reset Function Automotive Auto For Cars Diagnostic OBD ODB2 Scan Tool | FOXWELL NT624 Elite Full System OBD2 Scanner Engine ABS Airbag ESP with Oil/ EPB Reset Function Automotive Auto For Cars Diagnostic OBD ODB2 Scan Tool
    for innova and fort
    Check out Ancel JP700 OBD2 Scanner for Japanese Car Automotive Diagnostic Tool Engine Fault code read Clear at 42% off! ₱1,949 only. Get it on Shopee now! https://shopee.ph/product/159414345/...092?smtt=0.0.9
    Sent from my RMX2020 using Tapatalk
    Dec 2009
    Salamat po sa lahat sa inputs nyo. Nakatulong po sa pagbili.
    Ang nabili ko ay Ancel JP700 OBD2 Scanner for Japanese Car
    Automotive Diagnostic Tool Engine Fault code read Clear.
    Sa mga OBD1 Honda po, ano po suggestion nyo na OBD1 scanner?
    Uubra kaya na bumili ako ng OBD1 / OBD2 adapter para ma-reuse
    ko si Ancel JP700 OBD2 Scanner para sa Honda OBD1?
    hirap kasi sa obd 1, kanya kanya manufacturer ng protocols
    my bad ...
    for innova and fort
    That ancel maybe for labeled for japanese and will almost surely read toyota but just not the IMV models.
    thanks. very informative.
    IMV ba like fort or hilux? afaik gumagana sya doon
    Dec 2025
    Youcanic is a great option.
Recommended OBD Scanner?
