Results 1 to 10 of 12
- Dec 2009
- 41
August 7th, 2020 09:24 AM #1Planning to buy OBD Scanner na OBD1 / OBD2 compliant.
Please recommend brand and specific model that you
have used or if you have any idea ano magandang bilhin.
If I am going to buy OBD2 scanner then buy a OBD1 / OBD2
adapter, please suggest the brand and model as well.
I will use it for Honda OBD1 ECU and for 2015 Montero / 2015 MUX.
Your input is highly appreciated!
- Jul 2009
- 2,618
August 7th, 2020 10:22 AM #2halos lahat naman ng obd2 scanner will easily read honda and mitsubishi isuzu protocols. cheap generic ones will do fine even the blue tooth based dongles will work. Branded ones autel, inova, actron if you like some can reset abs srs too but they are not cheap especially if you are not using them on a regular basis. kun DIY lang you do not have to spend that much. personally hinahanap ko yun nag babasa din ng toyota IMV vehicles. Aside from professional grade obd scanners ( read: super expensive) wala pa ako mahanap nag babasa ng toyota IMV(diesel innova hilux fortuner hiace) . mga sedan cuv gas suv nila no problem basahin. I've borrowed a midrange autel maxi diag elite di din mabasa toyota imv.
August 7th, 2020 12:01 PM #3
It has an OBD-II ‘style’ DLC connector but it doesn’t seem to be using the standard OBD-II signaling protocol. None of my OBD-II scanners (ScanGaugeII and UltraGauge) can read anything.
So I got from eBay Toyota’s own PC software, Techstream. It comes with an OBD-II-to-USB dongle and it's not expensive (ok, it's not what you'll call a 'legit' copy either). Though, you will need a laptop and a bit of skill to use it and in case it wasn't obvious enough, this is a serious troubleshooting tool and it's not meant to be installed semi-permanently like a ScanGaugeII, et al.
I was able to clear a stored DTC and monitored a few other things during one of my commute some years back. That was it.
August 7th, 2020 01:02 PM #4
ito cheap and totoong ver 1.5 from ancel
https://shopee.ph/product/159414345/2381041520
August 7th, 2020 01:07 PM #5
- Jul 2009
- 2,618
August 7th, 2020 02:37 PM #6
August 7th, 2020 03:05 PM #7
my bad ...
eto pala gamit nya .. di gumana innova
₱10,999.00 -39% | FOXWELL NT624 Elite Full System OBD2 Scanner Engine ABS Airbag ESP with Oil/ EPB Reset Function Automotive Auto For Cars Diagnostic OBD ODB2 Scan Tool | FOXWELL NT624 Elite Full System OBD2 Scanner Engine ABS Airbag ESP with Oil/ EPB Reset Function Automotive Auto For Cars Diagnostic OBD ODB2 Scan Tool
for innova and fort
Check out Ancel JP700 OBD2 Scanner for Japanese Car Automotive Diagnostic Tool Engine Fault code read Clear at 42% off! ₱1,949 only. Get it on Shopee now! https://shopee.ph/product/159414345/...092?smtt=0.0.9
Sent from my RMX2020 using Tapatalk
- Dec 2009
- 41
August 8th, 2020 08:30 AM #8Salamat po sa lahat sa inputs nyo. Nakatulong po sa pagbili.
Ang nabili ko ay Ancel JP700 OBD2 Scanner for Japanese Car
Automotive Diagnostic Tool Engine Fault code read Clear.
Sa mga OBD1 Honda po, ano po suggestion nyo na OBD1 scanner?
Uubra kaya na bumili ako ng OBD1 / OBD2 adapter para ma-reuse
ko si Ancel JP700 OBD2 Scanner para sa Honda OBD1?
August 8th, 2020 09:47 AM #9
- Jul 2009
- 2,618
August 8th, 2020 10:30 AM #10
The Ten Commandments has been a traditional part of the Holy Week programming on local channels,...
Traffic!
